M5OD Shift Boot?
Old Jul 25, 2022 | 10:28 AM
demarpaint's Avatar
demarpaint
M5OD Shift Boot?
Hello, and TIA,
I have an 88 E-150 4.9L with the M5OD transmission. I recently replaced the clutch, flywheel, slave cylinder, RMS, front transmission seal, and other clutch related parts. The shift boot is in good shape, but the metal clips that hold it to the dog house were rotted and broke off. Finding a replacement boot for an E-150 has been pretty tough. IIRC there weren't/aren't many on the road. Any suggestions w/o drilling holes into the dog house would be greatly appreciated. Thanks.
Old Jul 25, 2022 | 12:19 PM
Mike1's Avatar
Mike1
Maybe you could post a couple of pictures to let us know what you're looking for. Most of us either have automatics or 3 on the tree.
Old Jul 25, 2022 | 12:39 PM
demarpaint's Avatar
demarpaint
I'm looking for the rubber shifter boot. On the bottom are metal clips that grab the underside of the engine cover, there are 4 IIRC. Two on the bottom rotted off, and the boot slips down as in the picture. I can drill holes in it and use self tapping screws, I'd rather not. It is not the same boot used in the PU trucks or the Bronco.
I'm the original owner. Over the years I've had it in for tires, alignments, and annual state inspections, no one has ever seen an E-150 with a 5 speed stick. Searching for that boot tells me there aren't many around.
Old Jul 25, 2022 | 12:57 PM
Mike1's Avatar
Mike1
I have an idea of what you're talking about but not sure what they look like. Perhaps you can use something like these U-clips maybe glued to the backside of the base plate or if there's slots for the clips to seat into you could maybe use die grinder to modify some clips to fit?? Hope the link helps
https://www.google.com/search?q=U-cl...h=652&biw=1280
Old Jul 25, 2022 | 01:24 PM
demarpaint's Avatar
demarpaint
Thanks for your time. I'd rather not pull the shifter yet, I will have it off soon to tune the van up.
Here's the busted clip, it goes into the bottom slot.
I twisted the boot around to show the top two clips which are good. It has three clips in total.
The clips are made of spring steel.
Old Jul 25, 2022 | 02:33 PM
Mike1's Avatar
Mike1
I think this is what you're looking for
Amazon Amazon
Old Jul 25, 2022 | 02:45 PM
demarpaint's Avatar
demarpaint
That sure looks like what I'm looking for, thanks!!!!!!!
PSDLOVER
May 4, 2022 05:01 PM
bagman1995
Oct 30, 2021 10:42 AM
cbwarrior
Apr 15, 2016 05:20 PM
dlsmithsr
Dec 2, 2009 05:19 PM
rbengl
1983 - 2012 Ranger & B-Series
Oct 7, 2006 10:58 PM
