Shift fork boot for 88 F150?
Old Mar 4, 2016 | 08:52 PM
cbwarrior's Avatar
cbwarrior
I have a bell from an external hydraulic clutch 88 F150. I am trying to find the rubber boot that goes around the shift fork. Ford says it is discontinued. I cannot find a source ANYWHERE. Does anyone here have a source for one? Or does anyone have a way f getting the measurements needed to try adapting another application boot to it? I swapped this into my CJ5, and I don't want to do any trails with it until I plug that hole up somehow. I'm willing to even go with a used part if it is in good condition.
Old Mar 5, 2016 | 10:51 AM
aj88V's Avatar
aj88V
Not sure which trans you're talking about. But if it's the Mazda trans, you might do better at a Mazda dealer.
Old Mar 5, 2016 | 10:10 PM
cbwarrior's Avatar
cbwarrior
It is for the external slave hydraulic clutch. The Mazda uses the internal slave setup.
Old Mar 6, 2016 | 09:08 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Have you looked at the '80 and up boot for a CJ? As you may already know the is when they went to a hydraulic clutch. The boot is a square instead of the previous rectangle used on the mechanical clutch.
Old Mar 6, 2016 | 09:58 AM
cbwarrior's Avatar
cbwarrior
Yeah, but they fit the mid-late 70's Ford bellhousing. You did make me think of measuring the original AMC bellhousing, maybe they'd be close to a match...
Old Mar 6, 2016 | 10:36 AM
Spktyr's Avatar
Spktyr
You may have better luck if you search for the "clutch fork boot" - shift forks are internal to the transmission and don't have boots. :P
Old Mar 6, 2016 | 05:12 PM
My4Fordtrucks
Have you asked over in the CJ section on Jeep Forum? There a few guys over there that have swapped in Ford power
Old Apr 13, 2016 | 12:13 PM
cbwarrior's Avatar
cbwarrior
Yeah, I go by Cutlass327 there. Took me forever to remember this login here because I haven't used this handle for at least 15 years...
The CJ boots I have are too short (top-bottom) by almost an inch. A user on JF had mentioned a couple p/n for ones he had luck with, so I ordered on of each (~$15 total somewhere), and no luck. I'm contemplating fitting the closest one and using silicone to fill in the gaps. Or even getting a piece of tire innertube material and screwing it over the installed piece and making a cover. If I could find something larger, I'd even cut the hole in the bell bigger to fit! I am itching so bad to hit some trails, but I don't feel like filling the clutch with mud/water/slop with the open hole....
Old Apr 13, 2016 | 02:08 PM
andym's Avatar
andym
This one? https://www.tomsbroncoparts.com/prod...9-302-351w-new
Or this one? https://www.tomsbroncoparts.com/prod...ord-bronco-new
It would help if we knew what transmission it was. It should be a T-18, but with Ford you never quite know for sure. If it is a T-18, it will have a diamond BW logo cast into the driver's side.
Old Apr 15, 2016 | 04:59 PM
cbwarrior's Avatar
cbwarrior
I got the bell from a salvage yard, told them I needed one from an 88 F150 with external slave. That's all I know.
Old Apr 15, 2016 | 05:20 PM
cbwarrior's Avatar
cbwarrior
I made this to bolt over the hole, the boot is a CJ application. I just have to remove the slave cyl, fit it in place, carefully drill/tap the holes, and use some stainless bolts to secure it. I'll put some sealer between them, too.
mcampbell545
Mar 27, 2012 10:59 PM
vektron75
Feb 23, 2012 06:37 PM
85GT5.0
Jul 15, 2009 08:13 PM
knoperj
May 21, 2001 02:26 PM
