Distributor Stuck in Place
Old Jul 22, 2022 | 12:10 AM
Melonmuziq's Avatar
Melonmuziq
I searched the threads but couldn't find my issue.
It seems that this would be common due to poor design on the 351M.
The distributor is not frozen but it is stuck in place so that the timing can not be adjusted at all. You may well know that the distributor sits down in a hole that can easily collect water causing it to rust in place.
I soaked it with WD40 and waited a few hours. Not much movement at all.
What is the best way to remove this distributor?
Thank you,
Last edited by Melonmuziq; Jul 22, 2022 at 12:24 AM. Reason: Can u delete this thread? I did find the answer.
Old Jul 22, 2022 | 06:03 AM
Mark8man's Avatar
Mark8man
Common problem for sure. Some of them can really be frozen. It took me a week of perserverance and patience. Applying heat with an oxy/acetylene torch to the block around the distributor. Repeated heat, soak, cool, cycles and it finally started to rotate slightly and once it does that you are on your way. Do not try to pry it straight up. Do not break the aluminum housing. Get it to rotate first. I believe the rapid heating ability of the oxy/acetylene helped. The process of heating and cooling (expansion and contraction) allows the penetrant to work better. Everyone has their favorite penetrant like pizza. I have been hearing GREAT things about Free-All from people who are mechanics for a living but I have not tried it yet. I have also had good success with a 50/50 mix of acetone and transmission fluid. Some penetrants seem to work better in certain situations so don't be afraid to experiement with others.
On a side note - I have found it easier to search google than using the search function here. I end up finding threads on FTE using google that I can't find by using the forum search function.
Old Jul 22, 2022 | 06:23 AM
f5fordgirl's Avatar
f5fordgirl
You said not much movement at all, if you have movement, you're on the winning side, snake oil and moving back and forth, it will come out.
Old Jul 22, 2022 | 05:07 PM
i-w's Avatar
i-w
I used a cv joint puller
Looks like a slide hammer with a fork on the end.
Amazon Amazon
Old Jul 22, 2022 | 08:06 PM
DJLF150's Avatar
DJLF150
1st Gear
Smile
I had the same issue with my 78 F150 351M, for over a year i kept trying different penetrating oils, banging on it, and heating it, nothing worked. Then I tried CRC Freeze-Off Super Penetrant that I bought from Amazon, I heavily sprayed the base of the distributer, let it sit there for about 5 minutes, and it came loose. Good Luck!
Old Jul 24, 2022 | 10:32 AM
5851a's Avatar
5851a
It's not just the M engine, it's been a problem since the Yblock days. patience is your friend. I spent weeks on a 400 once.
Old Jul 25, 2022 | 01:28 PM
Pickupmanx2's Avatar
Pickupmanx2
PB Blaster, found this years ago, been using it since, and yes, patience grasshopper, patience soak it, bang it, soak it, wiggle it, soak it, bang it, soak it, wiggle it... it'll move soon!
Old Jul 29, 2022 | 04:22 AM
Ozzie H.'s Avatar
Ozzie H.
On my 460 I used penetrant and appropriately sized bolts and coupling nuts to "press" it out. Balancing the forces are required. Before re-installation I cleaned the mating surfaces and used some anti-seize.
chris989
Sep 19, 2021 07:52 PM
warren561
Sep 9, 2014 08:42 PM
jesse_h97
May 20, 2009 11:08 AM
green 1969 f100
Mar 27, 2005 05:52 PM
dillon1033
Feb 9, 2003 12:52 PM
