Sponsored by: Real Truck
Removing Front Drive Line.
Old Jul 20, 2022 | 02:27 PM
PJWhelan's Avatar
PJWhelan
Long story short.....I need to remove the front driveline in my 2002 F-250 XLT 4WD CCLB. I removed the from 4 bolts and brackets from the front differential and removed 4 bolts from the point at the transfer case. Now What??
What do I now to either drop the front or rear of this drive line. It has been on there for years as I have never personally removed it....I just need to really move the front out of the way to get to my broken Oil Tube repair....
Old Jul 20, 2022 | 04:33 PM
WWR's Avatar
WWR
I'm guessing front is straps and t-case end is a flange?
The flange is hubcentric, give it a few taps and it'll come free. Rather suddenly. I'd leave 2 bolts in a few turns.
The front will pop out with a pry bar. Place thru gap and push against the cross of the u-joint. BE CAREFUL, the caps can walk/fall off then you're playing pick-up-needles
Old Sep 25, 2022 | 09:39 AM
PJWhelan's Avatar
PJWhelan
A follow up question from this front drive line.....At the rear of the front drive line, once all four bolts are removed you're saying just pound on the flange? So there is nothing else holding it to the transfer case once the bolts are out?
Old Sep 25, 2022 | 02:06 PM
WWR's Avatar
WWR
It's hub centric so it locates on a tiny lip. It'll come off like any rotor, drum or many wheels
Old Sep 26, 2022 | 08:14 PM
2004 F450's Avatar
2004 F450
WWR said "give it a few taps" not pound on it.
Old Sep 27, 2022 | 07:20 AM
Dan V's Avatar
Dan V
Rust is a great fastener.
PJWhelan
Sep 5, 2021 08:25 AM
marcusjb
Jun 13, 2016 06:11 PM
Bigbruce
Aug 20, 2013 08:56 PM
fordboy2
Jan 10, 2010 08:35 AM
Kansas-Mike
Mar 22, 2005 03:30 PM
