VIN Decode please!!
Old Jan 30, 2012 | 11:23 PM
Pickupmanx2's Avatar
Pickupmanx2
VIN Decode please!!
Hey Bill, Numbers,, or whomever also wants to,, could I get some info,, lookin at this Supercab,,,
X155KDE5530
W.B - 155
Color - UM
Type/GVW - X153
Body - QTM or OTM
Trans - K
Axle - 13X
Thanks!!
Joe
Old Jan 30, 2012 | 11:37 PM
fordfanatik's Avatar
fordfanatik
VIN Number Decoder offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
try this out. vin doesn't seem right too me.
Old Jan 31, 2012 | 10:55 AM
Pickupmanx2
X is for supercabs,,,
Originally Posted by fordfanatik
Old Jan 31, 2012 | 11:43 AM
JB78f150's Avatar
JB78f150
Ya I can't get anything for it either. Somebody with better books will have to do it.
Old Jan 31, 2012 | 12:52 PM
Pickupmanx2
Hey Numbers!!!
Old Jan 31, 2012 | 01:03 PM
bucks77ford's Avatar
bucks77ford
X15-F150 Supercab 2wd
u may want to check the vin again. the engine code should be an S for 1979 which would be a 400 4bbl
kansas city plant
UM-must be a two tone pastel sand and white
automatic
2.75 gears
Sand Vinyl and Sand Cloth
Old Jan 31, 2012 | 04:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
X155KDE5530 // W.B - 155 / Color - UM / Type/GVW - X153 / Body - QTM / Trans - K / Axle - 13X
Just what you need, another truck.
X15 = F150 2WD Super Cab Pickup.
No such VIN engine code as 5, it's prolly an S = 400 2V
K = Kansas City MO Assembly Plant.
DE5530 = 1979.
155" Wheelbase.
UM: U = Pastel Sand / M = Wimbledon White.
X153 = F150 2WD Super Cab Pickup, 6,400 lbs. Gross Vehicle Weight Rating.
QTM: QT = Sand Cloth & Sand Vinyl - Ranger / M = Super Cab.
K = C6 Cruise-O-Matic.
13X: 13 = Ford 9" Rear Axle / 2.75-1 / non Limited Slip / 3,750 lb. Rear Axle Capacity / X = ? No such code, take another look-see.
Note: FTE VIN decoders aren't worth TWO CENTS! Have multiple errors and omissions.
Old Jan 31, 2012 | 09:13 PM
Pickupmanx2
Ummm,,, is there such thing as too many?!!
YUP supposed to be S
DE5530 = 1979.
155" Wheelbase.
13X: 13 = Ford 9" Rear Axle / 2.75-1 / non Limited Slip / 3,750 lb. Rear Axle Capacity / X = ? No such code, take another look-see. IT IS AN X,, clear as day,,, didn't know if that was for like P/S?
Thanks Bill!!
Old Feb 1, 2012 | 12:55 AM
NumberDummy
I looked in 5 different '73/79 truck catalogs, 1 car parts (Bronco) catalog, couldn't find X listed.
It might refer to P/S, but Ford usually used J for that purpose. It might refer to a tilt wheel. Hold the wheel with one hand, gently press the turn signal handle forward with t'other.
If it has a tilt wheel: BOING!
Old Feb 1, 2012 | 01:24 PM
bucks77ford
Little things like these are interesting when VIN tags have codes that aren't listed in the catalogs. Just like the "ford plant" code in the F750 thread. Wonder how many more things like this are out there? I'd like to see pics of the VIN plates. Kinda like the whole F13 code that no one seems to know what that is.
Old Feb 2, 2012 | 11:20 AM
Pickupmanx2
If I could post a picture,, I would! Clear as day,, X
Old Feb 2, 2012 | 12:41 PM
BDawg171's Avatar
BDawg171
Speaking of VIN's and unusual things, my recent discovery of the VIN on the frame had a little "Star" engraved right after the number. Any thoughts as to what that would have been for?
Old Feb 2, 2012 | 05:36 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Mine has the same thing, an asterisk after the front frame VIN. On the hidden VIN the asterisk is at the beggining of the VIN.
I don't think the asterisk has any real significance.
Old Mar 31, 2012 | 08:39 PM
chris4735's Avatar
chris4735
f15ycw80913 i need to know the engine and trans please
Old Mar 31, 2012 | 09:09 PM
mikeo0o0o0's Avatar
mikeo0o0o0
360 2bbl. To tell the trans. need the trans code from the warranty plate mounted on the drivers door.
