Rag joint to universal joint
Old Jul 15, 2022 | 09:48 PM
68_f100's Avatar
68_f100
Has anyone ever converted the rag joint on the factory steering column to a universal joint? I have a pretty good idea how I’m going to do it but was curious if anyone else had down this. I don’t see a need to reinvent the wheel if there is already a good way.
Old Jul 15, 2022 | 10:45 PM
tbear853's Avatar
tbear853
A rag joint used to be used in cars as a flex coupling in the dcrive train, they take no lubrication, they work. They are fine for steering in my book. They also allow for slight changes in length like when the truck flexes or hits a hard bump and the cab bushings compress slightly. Easy to look at for condition, easy to replace the rag, transmits rotation about perfect.
Old Jul 16, 2022 | 04:56 AM
68_f100's Avatar
68_f100
Everything you said is true. I’ve not had any trouble out of mine the past 12 years I’ve been driving it. Unfortunately it has to go because I’m updating to a power rack for steering.
blake in spokane
Jan 8, 2021 06:37 PM
shorerider16
18
Jul 22, 2016 06:48 PM
70-360fe
30
Mar 8, 2013 06:09 AM
VolvoDude
1978 - 1996 Big Bronco
Nov 28, 2010 05:11 PM
big64
Jul 11, 2009 02:17 PM
