Steering column/rag or u joint
Old Feb 25, 2013 | 08:36 AM
70-360fe's Avatar
70-360fe
Slowly getting some work done on tilt steering column. Wanted some thoughts
advantages/disavantages on using a rag joint or a u joint for steering box connector. Thanks!
Old Feb 25, 2013 | 09:37 AM
jim collins's Avatar
jim collins
I used a good sealed bearing U-joint when i put in a tilt from a 79 F-150. I never did like the looks of the rag joint, Borguson U-joint is a lot cleaner looking. I never did trust the safety of a new rag joint let alone one that's been covered with motor oil for about 100,000 miles. My $.02 worth.
Old Feb 25, 2013 | 10:35 AM
Freightrain's Avatar
Freightrain
I'd go with a nice U joint also if the possibility came about. The rag joint is so 1960's.
Old Feb 25, 2013 | 11:38 AM
70-360fe's Avatar
70-360fe
I'am leaning towards a u joint, was a little worried about vibration. Do you thing that would be a problem?
Old Feb 25, 2013 | 11:54 AM
jim collins
No vibration in mine, it has power steering , so i don't know how it would be with manual steering. I have Three U-joints and a stabilizer bearing in the steering shaft in a street rod, no problems which was harder to do than my truck. Don't get cheap made ones , you'l get what you pay for.I used Borguson , may not be the right spelling , but there are other well made ones.
Old Feb 25, 2013 | 01:37 PM
70-360fe's Avatar
70-360fe
I'am hoping to use the original one from my junk yard column. Have to do some more homework to see if I can make it work. If not I will look into Borguson, thanks!
Oh, I have power steering also so it sounds like it should work.
Old Feb 25, 2013 | 02:20 PM
Freightrain
Try here:
Steering Joint from Speedway Motors, America's Oldest Speed Shop
LMC offers a kit, pricey though.
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=97
Old Feb 25, 2013 | 05:30 PM
jim collins
Check the size and style of joint you will need before buying it, they are expensive. Mine was 3/4 x 36 spline on both ends, yours may be different.
Old Feb 25, 2013 | 06:04 PM
70-360fe's Avatar
70-360fe
I have 3 piece shaft the bottom slips off so it will be easy to shorten. The u joint is connected to the bottom section. Don't know about the u joint end that connects to the gear box, if it will fit I'am good. If it doesn't I will look at your posts for a correct fitting joint. I'll remember to check diameter if I have to order one. Thanks for the links and info on your column, makes me feel better about the u joint
Old Feb 25, 2013 | 06:57 PM
jim collins
"Freightrain " posted the link but they are not hard to find.
Old Feb 25, 2013 | 07:04 PM
68cabby's Avatar
68cabby
I'm gonna be rebuilding my column soon and looked at the Borguson u joints. I have a manual box and rag joint setup. Is it as easy as switching out the rag joint and slipping the u joint on?
Old Feb 25, 2013 | 08:12 PM
70-360fe's Avatar
70-360fe
[QUOTE=jim collins;12883302]"Freightrain " posted the link but they are not hard to find.[/QUOTE
Ops sorry about that.
Took a quick look at the gear box connection on my f-100 looks like it will unbolt and will pull off. I have to look at the connection on the tilt column to see if it will fit on the gear box. Don't know yet if is a pull off rag joint connector and connect the tilt u joint connector. Hoping but wouldn't know till this weekend when I get some time to work on column.
I will post once I find out.
Old Feb 25, 2013 | 08:25 PM
70-360fe's Avatar
70-360fe
Just remembered when I rebuilt my 70 f-100 column it's a solid shaft. The tilt column is a 3 piece that comes apart and has a u joint connector on the end piece. I think you column is solid like the one in my f-100 and the rag joint connector would have to be cut off. Then you have to find a u joint connector that would fit both the gear box and the solid steering shaft end.
http://www.google.com/imgres?imgurl=...9QEwCg&dur=786
This is like the tilt steering column I'am using, center drive shaft comes apart in 3 piece with j joint already connected.
http://www.fordification.com/tech/images/colshort15.jpg
Your shaft end should look like one of these.
Old Feb 25, 2013 | 09:18 PM
68cabby's Avatar
68cabby
Yes mine looks like the bottom one. Darn. Is Hafta cut the shaft or buy one of theirs
Old Feb 26, 2013 | 07:37 AM
jim collins
Somebody told me the solid one just had that flange pressed on and it can be removed showing spines under it. I don't know I have a couple but have never checked them out. My tilt column came from a 79 F-150 and had 3/4 x 36 spines on it and the gear box was the same, making it a easy bolt on project. 78 /79 Broncos will have the 3/4 x 36 spline shaft too I believe.
