rag joint
Old Jul 10, 2009 | 10:00 PM
big64's Avatar
big64
rag joint
i saw on ebay a rag joint for the steering wheel . i pulled the top part of column apart and the bairings look good . could the rag joint be worn out causing all the wobble and is it hard to replace.thanks
Old Jul 10, 2009 | 11:17 PM
HrdDrv's Avatar
HrdDrv
You should be able to determine if the joint is bad or not. Visually, if it looks like it's frayed, or disfigured, it's shot. If your steering is wierd, well...
There's 2 bolts, going through the joint. You need to keep the steering wheel straight, loosen the bolts for the rag joint, and seperate them. Replace the ragjoint, and retighten. Let us know how it goes. Last time I replaced one, it was for a '71 Chevy.
Old Jul 10, 2009 | 11:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You saw the rag joint on ebay, but what is it really for?
Ford did not furnish the steering coupler (rag joint) separately for F100/350's after 1981, as it's part of the steering shaft & coupler assembly.
Old Jul 10, 2009 | 11:43 PM
HrdDrv's Avatar
HrdDrv
Are we actually looking at tie-rod/drag link issues here? Pitman/idler arm? I can't see a rag joint causing 'wobbly ' issues.
Old Jul 11, 2009 | 02:17 PM
outdoorgirl92336's Avatar
outdoorgirl92336
I'm having a problem with a rag joint replacement right now. The two bolts just turn and turn. We can't get them loose. Is there a trick to this or should I get a sledgehammer?
rjhesseltine
1997 - 2003 F150
Jun 1, 2015 09:01 PM
stercorarius
Mar 14, 2015 11:15 PM
R. Tovar
18
Nov 19, 2014 06:28 PM
benbuilder
Oct 26, 2013 04:31 PM
fasttang757
Jan 28, 2008 07:32 PM
