Door won’t lock
Old Jul 13, 2022 | 04:14 PM
Anatta's Avatar
Anatta
Door won’t lock
Having an issue with my passenger side door. I’m not able to lock the door using the key without pushing the door in with my body weight after it’s closed. It seems to close fine, but just won’t lock when turning the key unless I put all my weight on the door. Any ideas? Is this likely an issue with the lock mechanism, the door itself, door latch, etc? Thanks
Old Jul 13, 2022 | 06:50 PM
john jamieson's Avatar
john jamieson
Have you cleaned/lubricated any of the linkages and assemblies? That is where I would start. I need to do it to my '64 drivers side door. I just haven't had the time and I have an old storage pocket that may fall apart when I take it out.
Old Jul 15, 2022 | 01:59 PM
Truck4SF's Avatar
Truck4SF
First make sure your door is aligned. If so, you can adjust the lock striker plate (the part installed in the cabin, not in the door). Loosen the screws and make the adjustments. One way is to loosen it slightly and close the door gently. Open the door and raise the striker plate by 1/16" or a bit less. If you have to press the door in, it means it is too far in and needs to move out a bit. It might be moved in over the years or due to a new door seal which is thicker.
Jdnet
Jun 29, 2020 07:56 PM
20015.4f350
Nov 11, 2015 11:37 PM
Tennessee Toy
Feb 13, 2011 08:06 PM
ldruth
Jun 22, 2004 02:44 PM
stk541
Mar 30, 2004 07:53 PM
