Help! Electrical Issue
Drove to meet up with some friends Wednesday. When leaving to head out, it would not start. Seemed to be turning over cleanly but would not run. Kept trying. Opened the hood like I thought I would see something (knowing I wouldn't). Closed it, got back in, and it cranked like normal. Drove to a couple of more stops and everything seemed fine. Left late Friday evening to visit a friend about 30 minutes away. All was good but about halfway there, I notice the airbag light is on. I honestly couldn't remember if it was normally on or not but it caught my attention so I think not. Just a few minutes later, all the gauges went to zero and the radio shut off. The panel also seemed to dim. Engine is still running fine. They all come back on a couple of minutes later then shut off again. A few minutes later, the AC goes off. I try to put down a window and it doesn't work. I pull off the highway and I notice that the lights flicker with the blinker. I get to a gas station and pull in. I shut down. It doesn't want to start back up but then it does. Gauges still down. I drive a tad and it shuts down when I hit the brakes. I repeat this cycle a couple of times to get parked somewhere safe. I call roadside assistance to get towed and start googling.
Fast forward to the truck being dropped at my house. I start it up and all is fine for a couple of minutes and then it all goes down again. I didn't try to drive it this time. I got out the multimeter and the passenger side battery is reading about 12.5V and the drivers side is 9.6V. I start it up and test the voltages and they are still the same. This leads me to believe the alternator is bad. I put the batteries on chargers so I can take it to the local store later to get the batteries and alternator tested. Get home from work and try to crank it and have the same issue as Wednesday. Turns over good but never starts. I give up for the night.
So my question, anyone have any clear idea what might cause all of this? Is it possible that the starting issue is related to the electrical issue? That doesn't really make sense to me but the timing is suspect. I really need to take it on a 6-7 hour drive tomorrow but I do not want to be stranded.
Thanks in advance.
David
The discrepancy of battery voltage. The alternator charge to the passenger battery flows to the driver's battery with the crossover cable. So your low battery voltage on the driver's side is not necessarily an issue of the alternator. You could have a bad battery on the driver's side that is taking down everything, or, as we've seen in the past, a bad cable or connection between the batteries. A bad negative cable on the driver's side could also isolate that battery.
So first off, as we have learned in the past, post up pictures of your two batteries so we can see the cables and the terminals.
The batteries should be charged individually and tested for capacity at AutoZone, Advance, or whomever. They do it for free. If you can't get a printout, write down the values and post them here.
If the driver's battery is not well connected, the low voltage can cause all the problems you mentioned.
You might also have a cluster issue or a relay issue, but the battery situation has to be dealt with first.
Driver's Side Battery
Drivers Side Positive Terminal
Drivers Side Negative Terminal
Passenger Side Battery
Passenger Side Negative Terminal
Passenger Side Positive Terminal
If it were me, I'd start with two new batteries and get into that cabling clean up and see where you are. Hopefully your alternator is just fine, but let's start with some basic stuff...
All that said this may not get you running, but it really needs addressed from those pics, Good Luck
It looks like the previous owner was trying to work out issues and not buy new cables. The factory terminals are not that great, therefore, the replacements. You don't have to have the batteries in the vehicle to get them tested; it's actually better if they are not. The batteries are a few years old and, depending on their history, may not be in the best shape. A capacity test would tell, but they could be replaced at their age. I often recommend getting them from Walmart, not that Walmart batteries are better than any part store batteries, but they are about the same quality while less expensive, and I've had good life out of them. Around here, throw a stone and hit a Walmart.
The type of positive clamp on the passenger battery is not a good design, but it's often used due to the shortness of the starter cable. Not sure if you are willing for the expense of new cables, which may also depend on your ability to clean everything up and possibly install new lugs.
So based on what I am understanding, I should have continuity between the 2 positive terminals and both batteries should theoretically read the same voltage even if one is bad. I just tested and could not get continuity between them with my multimeter which would indicate a bad crossover, at a minimum. Is this correct thinking?
There should be no difference in voltage between the two battery positive terminals and a common ground. To test continuity between the two terminals, they should be disconnected from the battery terminals. I don't know if that's how you did that; we don't know each other well.
All those terminal connections should be cleaned; every lug, terminal, and post. Considering the condition of all that from the last owner, the grounds should probably be cleaned as well. I've got a video on that.
To clean the bared cable wire, you can let the end sit in white vinegar for some time, wash it, then dunk it in a baking soda solution to neutralize. There are electrical cleaners out there you can also buy.
Back to yard work for a while.
