Trying to pin point what the issue is with my truck im pretty sure it's electrical i'v been told a few times to get a new computer for it the issues are it's a little hard to get into Park it starts to roll back or goes into Reverse (almost ran over me once) when in Drive with overdrive on (it doesn't turn off or on) it shifts randomly like it shifts to fast from 3rd to 4th it's almost instant and it won't go into 2nd or 3rd sometimes it acts normal and shifts threw all gears fine Code reader says code 111 10 then 512 and won't read any other codes Truck sat for 8 years in my yard transmission gasket failed and all transmission fluid leaked out i filled it back up replaced gasket and filter Already replaced speed sensor in rear diff it didn't change anything
Trying to pin point what the issue is with my truck im pretty sure it's electrical i'v been told a few times to get a new computer for it the issues are it's a little hard to get into Park it starts to roll back or goes into Reverse (almost ran over me once) when in Drive with overdrive on (it doesn't turn off or on) it shifts randomly like it shifts to fast from 3rd to 4th it's almost instant and it won't go into 2nd or 3rd sometimes it acts normal and shifts threw all gears fine Code reader says code 111 10 then 512 and won't read any other codes Truck sat for 8 years in my yard transmission gasket failed and all transmission fluid leaked out i filled it back up replaced gasket and filter Already replaced speed sensor in rear diff it didn't change anything https://www.youtube.com/watch?v=chJ3m7FJY&ab_channel=HotRodGavin
Oh.
how about we slow down. did you define the codes yet? how did you take them? how much ATF is in your trans. You had THAT bad of a leak to lose it all???
all i can get it to read are 111 10 then 512 nothing else 512 say's it has a code reading issue i used a Innova OBD1 code reader, it's full of ATF i put like 8 quarts in it and it's showing full, when i first started to work on it there was atf all over transmission pan and nothing was showing on trans dipstick while running when up to temp
well you said you fixed the leak and put ATF in. 8 quarts to me doesnt seem like that would recoup a full pan drop, although I should ask are you 4x4 or 2wd?
Im sorry i couldn't exactly remember but they gave me Mercon SP not LV i hope sp fluid also works
trust mark on this he literally is the authority on the subject the only fluid ford sells that should be used is Mercon V. I understand how easily a parts store person can mislead you.. been there, in the future, I would recommend consulting a trans shop + a dealership for 2 likely to be good answers, do your own research online, etc. parts store people tend to get very confident despite not much experience. sadly those positions unless you find a really nice cushy leadership job somewhere, usually the drones only get 9-10 an hour and they will hire someone out of hs who doesnt literally know how to put washer fluid in their car, if they have a car.
