Ford E4OD Shifting Problems
Old Jul 12, 2022 | 07:53 PM
  #31
AuroraGirl's Avatar
AuroraGirl
Originally Posted by Gavin D
Just topped off fluid and took it for a test drive still acting the same 3rd to 4th shifts to fast is there anything else I can do because I'm not paying to have trans rebuilt Also it will not go into park it slams into reverse won't even shift to second in 2
Well since you ignored important information and questions, I’m not sure it quite makes sense to try and help you diagnose since it’s falling on def ears
Old Jul 12, 2022 | 09:42 PM
  #32
Gavin D's Avatar
Gavin D
Trailering
i don't understand i did exactly like it was recommened to change the fluid i drained all the fluid out of transmission and torque converter and re filled with Mercon V
Old Jul 12, 2022 | 09:47 PM
  #33
subford's Avatar
subford
He is talking about the T30 screws. You have never replied that you checked the T30 screws.
Old Jul 12, 2022 | 09:51 PM
  #34
Gavin D's Avatar
Gavin D
Trailering
none of them are loose i think the cable going to it is damaged as i can shift the transmission from the bottom while it's in park
Old Jul 13, 2022 | 01:17 AM
  #35
McLeod's Avatar
McLeod
The transmission pan with the raised ribs between the bolt holes is for the (throw away) cork gasket.
The reusable rubber pan gasket needs to have a transmission pan with smooth surface between bolt holes.
Old Jul 15, 2022 | 02:27 AM
  #36
AuroraGirl's Avatar
AuroraGirl
huh.. my pan I THOUGHT had no raised ridges, but it doesnt contain the "This pan has a reusable gasket" text in it either(nor a drain plug) but I didnt take any pictures with the gasket off the perimeter. guess i will not know until it comes down again lol
Old Jul 15, 2022 | 06:40 AM
  #37
subford's Avatar
subford
If you have the wrong gasket it will leak very bad as in putting the reusable gasket on a pan that is made for the cork gasket.
I had to switch to a newer style pan to use the reusable gasket.
Old Jul 15, 2022 | 06:48 AM
  #38
AuroraGirl's Avatar
AuroraGirl
I was sad when I saw cork when I did my change because I have a 96 truck, so I also didnt have the filter with the little "legs" on it that ensure it stays retained in the seal o ring thing. But thats okay. I figured even if I had a newer pan to use the elastomeric gasket, Id still eventually want a 4r100 pan with a drain bolt.
Old Jul 15, 2022 | 02:06 PM
  #39
seschenburg's Avatar
seschenburg
If you can do proper shifting at the transmisson then the problem is likely between there and the shifter on the column. If I remember correctly the cable has an adjustment to take up slack or add slack. It's not far from the transmission end. If you've checked things under the dash, consider making some adjustments here. Try to note where you start before turning it so you can put it back if you needed to. Count your turns, that sort of thing.
fordismyreallastname
Modular V8 (4.6L, 5.4L)
Aug 26, 2021 01:25 AM
hadam
15
Aug 13, 2021 09:36 AM
Todd89
Nov 30, 2017 08:09 PM
94OBS351W
Dec 30, 2015 12:58 PM
mikerans
Jul 17, 2011 10:08 PM
