Upper Intake Manifold Stuck
Old Jul 14, 2022 | 02:33 PM
jackhunter's Avatar
jackhunter
Hey guys,
I'm having some real trouble removing the upper intake from my '93 302 EFI. I have removed all 6 bolts, and I still can't get the thing off. Some fool decided to use RTV the last time it was apart, and I now cannot pry the thing off. I have tried using a rubber mallet to loosen things up, a pry bar + 2x4, and I even ran the engine for a while with all of the bolts out to see if the heat would loosen things up.
Does anyone have any other ideas? - I need to get the darn thing off so I can change the injectors.
Thanks!
Jack.
Old Jul 14, 2022 | 02:41 PM
chesster51's Avatar
chesster51
Maybe a torch around the perimeter? How long was the 2x4? I would think with about a 6' long one going in under the upper from the passenger side and prying up it would break loose, maybe you've already done that but I can't imagine RTV being able to when that battle.
Old Jul 14, 2022 | 02:45 PM
jackhunter's Avatar
jackhunter
I used a small 2x4, and was bending my solid iron prybar lol. I'm about to go outside and try the long 2x4 + torch idea. I will update shortly.
Old Jul 14, 2022 | 02:48 PM
chesster51's Avatar
chesster51
If there's room, turn the 2x4 so the 3.5" side is vertical.
Old Jul 14, 2022 | 03:19 PM
jackhunter's Avatar
jackhunter
There's really limited room for a 2x4. I managed to get the throttle body off of the intake with the torch, baby sledge, and a brass rod. There's not really room to torch the upper intake itself, so I've just been going at it with the sledge and brass rod. Hopefully I don't crack the thing but honestly I don't even care if it gets it off.
Old Jul 14, 2022 | 03:39 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I doubt you missed it… only double checking that you removed the support bracket on the passenger side.
Old Jul 14, 2022 | 04:04 PM
chesster51's Avatar
chesster51
I hope that's not the problem!
Old Jul 14, 2022 | 04:35 PM
jackhunter's Avatar
jackhunter
I removed it all. I should have mentioned that I was the fool who used RTV, so I was already familiar with the removal process . I finally got the thing out after beating the crap out of it. Now, though, one of the damn injectors is stuck. This project has been quite the pita.
Old Jul 14, 2022 | 05:54 PM
torq'ta 5 8's Avatar
torq'ta 5 8
Note: for self preservation, use half as much, RTV, if any at all, this time, on upper.
Old Jul 14, 2022 | 06:18 PM
jackhunter's Avatar
jackhunter
No kidding lol
Old Jul 14, 2022 | 06:30 PM
My4Fordtrucks
I install the plenum gasket clean and dry. No problems.
Old Jul 14, 2022 | 07:48 PM
torq'ta 5 8
Agreed, my almost 30yr, hasn't started cracking,
Old Jul 14, 2022 | 08:35 PM
My4Fordtrucks
I would be afraid that RTV could break off and make its way to the valves and cylinders.
Old Jul 15, 2022 | 12:06 PM
jackhunter's Avatar
jackhunter
I've never had any issues using it over the years, most 4 bbl intakes call for it on the China walls anyways. Clearly less is more, though.
Old Jul 15, 2022 | 12:32 PM
Scndsin's Avatar
Scndsin
As mentioned, the upper/lower gasket should be completely dry.
If the gasket moving during installation is a problem, whack the heads off a couple 5/16 bolts to use for alignment studs.
