Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
'64 F600 Vin decode help
Old Jul 8, 2022 | 06:56 PM
Pittsborojoe's Avatar
Pittsborojoe
1st Gear
New to this forum but seems like y’all are super helpful. Just picked up a 64 f600 and wanted to some help decoding vin to id motor and trans to bring the beast back to beauty. Here is pic of vin plate from door
Old Jul 8, 2022 | 08:18 PM
85e150's Avatar
85e150
Welcome to FTE! I'm moving you to the Large Truck forum where you will find other F600 owners and hopefully help.
F60 = F600 gas, 4x2
A = 330 2V MD FT gas V8. (First year for the FT. This one would have the FE crank and distributor drive, FT heads, manifolds, pistons, and other bits.)
N = Norfolk Assembly Plant
553118 = 1964 numerical series, July 1964 production
174 = 174 inch wheelbase
M = Wimbledon White
F600 = '64 to '66 F600, 17,000 lbs GVWR
E81 = I do not have clear info on upholstery and I couldn't find a match to this. Does this have a red interior and Custom Cab?
N = New Process model 435 four speed transmission --OR-- Dana (Spicer) model 5652 five speed direct transmission. (same code for both in '64/'65)
F8 = Eaton model 13802 two speed rear axle, 15,000 lbs capacity, 6.33/8.81 ratios
Your picture cuts off the front axle code if there is one.
17000 = 17,000 lbs GVWR
160 3800 = certified net HP @ 3800 RPM
22 = Charlotte District Sales Office
No special order, "bought off the lot".
Beware of widowmaker wheels--
https://www.ford-trucks.com/forums/8...l#post19892682
Old Jul 10, 2022 | 06:30 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Add my welcome. In the link posted by 85e150 you’ll see an old thread dealing with hub piloted widow maker wheels. That is probably gonna be important to you. The 1963 and 1964 F-600 trucks were so equipped. Stu
Old Jul 10, 2022 | 07:09 PM
85e150's Avatar
85e150
That link is the Widow maker posts, but I added direct access to the post about hub piloted wheels it up there and here it is:
https://www.ford-trucks.com/forums/1...l#post19232301
Woodchuck82
Large Truck
Mar 20, 2022 05:20 PM
55 dude
May 13, 2021 09:42 AM
ckmoehring
Large Truck
Apr 24, 2021 04:28 PM
NewFordOwner234
Large Truck
Apr 20, 2021 07:04 AM
gangstakr
Aug 20, 2020 11:32 AM
