Bucking/Jerking
Old Jul 7, 2022 | 04:43 PM
78Custom302's Avatar
78Custom302
Bucking/Jerking
I finally got my truck running but I keep getting this bucking/jerking thing happening when I am decelerating, then it will often stall when slowing to a stop. It also gets worse as the engine gets warmer. I installed new plugs and wires, cap and rotor, and thought that would fix it, but it is still doing it.
Old Jul 7, 2022 | 09:29 PM
440 sixpack's Avatar
440 sixpack
Doing it on deceleration is odd. your timing might be horribly advanced, does it kick the starter when you crank it ?
Or it could be dying and restarting, that could be several things.
Old Jul 7, 2022 | 09:48 PM
78Custom302
What do you mean by "kick the starter"?
It's not dying and restarting, I know that.
The starter has spun w/o catching a few times...
Under a load and accelerating, it runs great.
Old Jul 7, 2022 | 09:54 PM
78Custom302
Has anyone heard of this:
ISSUE
Engine mis,spark knock,buck/jerk,surge and other drive ability concerns may be caused by induction crossfire.This occurs because of improperly routed spark plug wires.
ACTION
If spark plug replacement is performed, the correct firing order and spark plug wire routing is essential to prevent the possibility of induction crossfire between cylinders.Refer to the following procedures for inspection of spark plug wire routing and firing order.Properly reroute the spark plug wires if required.
Old Jul 8, 2022 | 09:46 AM
FuzzFace2's Avatar
FuzzFace2
ISSUE
ACTION
yes it is a thing thst could happen but with today's better plug wires and if good I have not heard of it happening as of late.
If you are getting cross fire through the plug wires replace them.
Dave ----
Old Jul 8, 2022 | 09:50 AM
beartracks's Avatar
beartracks
Could be emmission controls related
Old Jul 8, 2022 | 10:18 PM
78Custom302
can you say more?
Old Jul 9, 2022 | 09:34 AM
beartracks's Avatar
beartracks
It's compicated, but maybe the smog air pump control if you still have it.
Old Jul 9, 2022 | 12:15 PM
78Custom302
Do you mean the EGR valve? I’ve never heard of a “smog air pump”.
Old Jul 9, 2022 | 07:08 PM
arnegrant's Avatar
arnegrant
My 2 cents
Double check the advance isnt sticking open
Take a quick look at the driveline components (brakes, etc)
Double check the timing with a timing light
Double check the plug wires are going to the correct cylinder
Check the plugs to see if there is anything off in one cylinder
Check compression
Throw a different carb on
Throw a different computer box on
Replace the distributor
traxx808
15
May 21, 2010 10:41 AM
j_crista
13
May 1, 2010 12:10 AM
stang74shelby
Sep 29, 2009 08:32 AM
greenexplorer
Jan 14, 2005 03:24 PM
pchristman
Dec 9, 2003 04:13 PM
