Mis-fire
Old Sep 29, 2009 | 06:36 AM
stang74shelby's Avatar
stang74shelby
Mis-fire
I set my timing to stock and when i punch the gas it pings like a bitch, i advanced it some and it still pings a little. I have replaced the coil (msd blaster), accel cap and rotor, new wires and plugs, new airfilter and exhaust. Any Ideas? my dad said possible play in the timing chain... truck has 154,000 miles on it.
Old Sep 29, 2009 | 07:28 AM
B Dobz's Avatar
B Dobz
If it`s pinging you want to retard the timing not advance it.you went the wrong way.you go counterclock wise to retard the timing.
Old Sep 29, 2009 | 07:29 AM
stang74shelby
Ok, did that, but still a light ping when accelerating......i got it back to where it should be stock
Old Sep 29, 2009 | 07:38 AM
B Dobz's Avatar
B Dobz
when you timed the truck did you pull the spout out?
Old Sep 29, 2009 | 07:50 AM
stang74shelby
yup, found the link about that yesterday, and pull the spout and set it.
Old Sep 29, 2009 | 08:29 AM
B Dobz's Avatar
B Dobz
I guess you set the timing at 10 degrees btc?if so you might have some play in the timing chain and need to bump it back to 8 and see what it does.
Old Sep 29, 2009 | 08:32 AM
stang74shelby
ll try that
