1990 AOD concerns
Old Nov 10, 2003 | 07:54 AM
wfs's Avatar
wfs
1990 AOD concerns
Hi,
I cannot go from Park or Reverse into OD. I can go into OD from D, and the OD does seem to be working. I assume this isn't the way it's supposed to work. My linkage down below is on its last legs, but it's still holding together. Would adjusting the TV cable have any effect on this, or does it sound like the tranny needs work?
Thanks!
walter (it's a 90 f250 4x4 w/ AOD)
Old Nov 12, 2003 | 07:15 AM
tulsaokjoel's Avatar
tulsaokjoel
Hi, sorry I can't answer your question, but I'm wondering if the AOD came standard in a '90 model?
Old Nov 12, 2003 | 07:54 AM
wfs's Avatar
wfs
As far as I know, it's stock. The Tranny Spotter's guide in the tech article section of this site lists it as standard as well.
Old Nov 12, 2003 | 01:40 PM
tulsaokjoel
Thanks I'll check it out.
By the way what does your truck do when you shift from park to OD or from reverse to OD? Does it stay in park/reverse, or does it go to neutral?
Old Nov 12, 2003 | 06:07 PM
wfs's Avatar
wfs
From reverse or park it just stays in neutral. Any ideas?
Old Nov 13, 2003 | 07:38 AM
tulsaokjoel
You might try posting this same topic in the 87-96 F Series forum. Someone there might have an idea.
hairyboxnoogle
Apr 1, 2017 12:11 PM
Donald Blankynship
May 3, 2016 07:45 PM
1990_Bronco_Custom
1978 - 1996 Big Bronco
Jan 10, 2012 10:26 AM
vee10td
Aug 15, 2011 10:34 AM
my91stealth
Dec 15, 2010 11:07 PM
