Sponsored by: Real Truck
ATF compatibility questions
Old Jul 4, 2022 | 11:10 PM
Mech644's Avatar
Mech644
2007 F350 SD, 5.4L with AT
In process of installing new engine and have drained power steering and AT fluids during the tear down. Owners manual states that Mercon SP should be used in the AT. I’ve read in a more than a few threads on here that Mercon LV is fine in place of SP.
Manual also advise that Mercon should be used for power steering as well as the transfer case. In the interest of only having one fluid on hand I’m inclined to use LV in the power steering and the transfer case.
Anyone have any strong feelings or info that says I shouldn’t?
thanks in advance for any responses.
Old Jul 5, 2022 | 07:01 AM
projectSHO89's Avatar
projectSHO89
Look up current recommendations at https://www.fcsdchemicalsandlubricants.com/ You can use either current (recommended) or original (okay) fluids in the other systems.
See Ford SSM 21114 regarding transmission fluid. This subject has been discussed MANY times over the last dozen or so years.
Randy777
Jul 22, 2013 05:15 AM
90pioneer
May 6, 2013 12:42 PM
fordman19762003
2004 - 2008 F150
Mar 11, 2012 11:46 AM
mich800
1997 - 2003 F150
Mar 17, 2008 09:13 PM
Scrib43
1983 - 2012 Ranger & B-Series
Aug 26, 2003 03:42 PM
