Transfer case oil???
Old Jul 18, 2013 | 07:34 PM
Randy777's Avatar
Randy777
I'm changing my transfer case and power steering fluid. Is any Mercon oil from Autozone ok or does it have to be Mercon SP? Some have said Dextron III will work too. Thanks for your help.
******** src="http://static.pricepeep.net/apps/tv-classic/pricepeep/tv-classic-pricepeep.js">*********>
Old Jul 18, 2013 | 07:50 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Mercon V for power steering.
Some use Mercon V in the transfer case, although Ford does not recommend it.
Spec is Mercon/Dexron III for transfer case.
Josh
Old Jul 18, 2013 | 08:54 PM
cheezit's Avatar
cheezit
check the owners manuel. Ford has a special transfercase fluid
Old Jul 18, 2013 | 09:22 PM
diesel_dan's Avatar
diesel_dan
My '07 manual says to use Mercon in the Xfer case, and between my two Fords, anything that calls for Mercon I've been switching to Mercon V (not sure Mercon is even out there now). I just put V in my Expy's xfer case 2 days ago... That's what I would put in the F350's if it needed it tomorrow -- our Expy is an AWD so the xfer case is always on...
Not sure if I'm helping here or asking for validation from Josh and Cheezit
Old Jul 18, 2013 | 09:39 PM
Bullitt390's Avatar
Bullitt390
Motorcraft Transfer Case oil = Mercon/Dexron III
So if one wants to spend $10+ a quart for overglorified T/C oil then by all means buy Motorcraft XL-12.
Josh
Old Jul 19, 2013 | 05:29 PM
cheezit's Avatar
cheezit
thank you. i could not remember the number but yes its xl-12.
i use the correct factory recomended fluids in my truck. what you opt to use is on you.
i gave the op the info he asked for while you suggested a possible undocument alternative that is not recomened by ford for use in the unit.
Old Jul 19, 2013 | 06:01 PM
Bullitt390's Avatar
Bullitt390
Says Mercon in my owner's manual every owner's manual for 6.0 truck.
You have Transfer Case Oil because Ford let the license expire for Mercon.
It's no coincidence the license expired with the debut of the 2008 MY Ford trucks and they call for the Transfer Case Oil.
Josh
Old Jul 21, 2013 | 05:10 PM
crlrca's Avatar
crlrca
Has anyone used the Royal Purple ATF in the transfer case?
Old Jul 21, 2013 | 05:37 PM
e250guy's Avatar
e250guy
My manual says Merc/Dex III. That's what I used.
Old Jul 22, 2013 | 05:15 AM
run6.0run's Avatar
run6.0run
Josh
Check out this deal I found.
They had about 20 qts. I didn't buy it tho. I run Mobil 1 ATF syn.
Same place I found this
I bought all they had of this tho.
Batgeek
Jun 13, 2019 11:06 PM
Dads79
2015 - 2020 F150
Feb 26, 2019 08:50 AM
Syncrowave
30
Sep 28, 2017 08:33 PM
parcours
Dec 22, 2016 10:03 AM
98SurplusExpy
Aug 12, 2013 03:06 PM
