Code P1660
Old Jun 30, 2022 | 05:04 PM
Ryan Spyker's Avatar
Ryan Spyker
1st Gear
Code P1660
How would y’all go about code P1660 Output Circuit Check Signal High I’ve been told to replace the pcm but I’m not too sure where I could get a new one or if there’s a fix that doesn’t require replacing the pcm could reflashing possibly work?
1997 F250HD 7.3 Powerstroke
Old Jul 1, 2022 | 08:51 AM
Talyn's Avatar
Talyn
Based on my quick look around as I had never heard of this.
It seems like its more IDM related than PCM related.
But somewhere there is an over voltage in the system causing the fault.
So, I would probably start with the IDM as its a big voltage regulator, so if its going bad, it might be pushing bad voltage to the injectors.
catman52987
Jul 30, 2021 08:27 PM
hotrodfeguy
Aug 8, 2018 07:20 AM
Restlesswildman
Jul 2, 2014 06:08 PM
wildstang
Aug 28, 2013 09:52 PM
2005f-150
Feb 7, 2012 05:23 PM
