New injector still have same codes
Old Sep 23, 2011 | 08:23 PM
dbarnett42's Avatar
dbarnett42
Replaced injector #8 and I still have a low circuit and contribution codes. Truck runs better but it still has a miss. What else could cause it. I know the new injector is good. Could it be the FICM or the wire harness. Looking for a direction to go. What should I check next.
Old Sep 23, 2011 | 08:28 PM
BLADE35's Avatar
BLADE35
Have you checked the Ficm voltage
Old Sep 23, 2011 | 10:29 PM
dbarnett42's Avatar
dbarnett42
FICM is 46 to 48 volts
Old Sep 23, 2011 | 10:40 PM
BLADE35's Avatar
BLADE35
could be a bad Ficm injector Driver
having 48 volts on the FICM is not 100% Guarentee that its Good
are you only getting codes for #8 cylinder
was the tip still on the injector that you replaced????
Old Sep 23, 2011 | 11:52 PM
dbarnett42's Avatar
dbarnett42
Only codes for #8. The tip is still on it. I will try to post a picture of it later
Old Sep 24, 2011 | 07:42 AM
tex25025's Avatar
tex25025
They didn't over tighten the oil rail when putting everything back together did they?
Old Sep 24, 2011 | 12:12 PM
dbarnett42's Avatar
dbarnett42
everything was tightened to the correct torque.
Old Sep 24, 2011 | 12:43 PM
BLADE35's Avatar
BLADE35
so were down to a FICM or a Ficm Harness
maybe you could DVM the harness for #8 for continuty
Old Sep 24, 2011 | 01:16 PM
2006powerstroke90's Avatar
2006powerstroke90
This is a wild thought of mine....
I am not sure if it will work or not.....
Maybe maybe not...Try using a plug from another injector...Lets say swap the plug from number 6 to number 8 vise versa...
Then if it says injector #6 low circut then you know its the harness...
Old Sep 24, 2011 | 01:37 PM
BLADE35's Avatar
BLADE35
Not to wild of thought Tyler Iv heard it mentioned before
Try to move the Low Circut code
but they both might show contribe issues since injector timing maybe off
but your onto something if the low circut moves
Cheezit has also mentioned using high beam lamp to load test circuts
Old Sep 24, 2011 | 02:50 PM
dbarnett42's Avatar
dbarnett42
If it's the harness is ford the only place to get one and does any one have the part number for it.
Old Sep 25, 2011 | 05:34 AM
npccpartsman's Avatar
npccpartsman
05-07 FICM harness 5C3Z-9D930-AA. Try Ebay. There are harnesses on there fairly often.
Old Sep 25, 2011 | 07:49 AM
dbarnett42's Avatar
dbarnett42
Thanks for the part number. Going to do some testing sometime this week and try to figure it out.
Old Sep 25, 2011 | 08:04 AM
npccpartsman
You might pull the harness out, strip off the convolute tubing, check all the wiring for chaffe's, and the plugs for bent pins. It's not shielded so unless it's broken internally you should be able to repair it. Also, check the FICM and FICM plugs for bent pins. The FICM guide posted in the tech folder can point you to which plug controls which injectors. Since #8 is right under the FICM I'm thinking a wire got FUBAR'd somewhere in that process, at least that's where I'd start.
Old Oct 5, 2011 | 06:47 PM
dbarnett42's Avatar
dbarnett42
update.
I got it fixed. It was the FICM wire harness. Got a new one from Tousley Ford and swapped it out tonight. The truck runs great. I probably did not even need to replace the injector but o well. At least I know how to replace it now. Thanks everyone for all of the input and suggestions. You guys rock!
