Strange fuel problem
Old Jun 27, 2022 | 01:18 PM
llama's Avatar
llama
I had removed my fuel rail and injectors to clean them. The truck had been sitting in the garage for a day, when suddenly fuel began to flow out of the disconnected fuel line. I quickly saw that I had left the key turned on and the fuel pump was running. I turned the key off and the fuel flow stopped. What would cause the pump to suddenly turn on? The truck was just sitting there untouched while I was watching a ball game in the garage.
Old Jun 27, 2022 | 01:52 PM
sandymane's Avatar
sandymane
Had the truck been in operating condition and the fuel pumps ran constantly with the key on, one common issue is PCM failure. When working with the components in your post, the battery should absolutely be disconnected. This doesn't answer your question but it would have prevented the issue.
Old Jun 27, 2022 | 02:09 PM
llama's Avatar
llama
Had not had the problem with fuel pump running before. The battery was disconnected at first. Then I reconnected it to check some electrical things and forgot to disconnect. Its just lucky I was there with a friend of mine watching Ole Miss win the College World Series
Old Jun 27, 2022 | 02:16 PM
sandymane's Avatar
sandymane
I certainly understand. When I replaced my intake manifold I forgot to connect the fuel line clips that slide over the lines and when I drove it, it died because the lines came off. . When I opened the hood I considered myself lucky also.
Old Jun 27, 2022 | 03:11 PM
sandymane's Avatar
sandymane
With the key on engine off and battery connected the fuel pumps should run for 1 to 2 seconds and shut off. Again, in operating condition the PCM would be suspect if the pumps continue to run. Or, perhaps the fuel relay is stuck?? If it isn't, your PCM should be removed and check the capacitors for bloating and/or leaking. If you are cleaning injectors you probably have had some issues with the truck running. If so, perhaps it was the PCM causing the poor running or fuel problem.
Old Jun 27, 2022 | 03:32 PM
llama's Avatar
llama
Yep. I am planning on checking fuel relay tonight. Hope that is it. I took fuel rail off because the injectors had become clogged. I suspect a dirt-dobber nest from when i had the fuel rail off to paint the plenum. Yes, I didn't tape over the ends while it sat.
Old Jun 27, 2022 | 03:40 PM
sandymane's Avatar
sandymane
If you suspect the fuel relay, you can swap it with the horn relay beside it to verify.
Old Jun 27, 2022 | 03:48 PM
llama's Avatar
llama
That is a good idea . Thanks
aussietom
Oct 8, 2020 07:59 AM
sand1
Oct 22, 2016 06:05 AM
wastingas
Escape & Escape Hybrid
Mar 9, 2013 10:09 PM
capitanjo
20
Nov 24, 2011 03:18 PM
