Bump stops
Old Jun 23, 2022 | 06:35 AM
butchd88's Avatar
butchd88
Trailering
Bump stops
I have a 56 with the Volare front clip, I am trying to set the ride height, The lower control arm bump stops are missing and new ones are not available, With the wheels hanging do I measure from bump stop that mounts on frame to the control arm or to torsion bar bracket, The measurement is 1 1/2 to 2 inches?
Thanks
Old Jun 23, 2022 | 08:43 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The bump stop, if you had it, would hit on the top of the torsion arm bracket where it bolts to the lower control arm. So measure to the torsion arm bracket. The stock bump stops are only approximately two inches tall.
Old Jun 24, 2022 | 06:40 AM
butchd88's Avatar
butchd88
Trailering
Thank you very much for the info. I found the measurement for the bump stop, They are 1 9/16 high so I will compensate for them, Thanks again.
Old Jun 30, 2022 | 10:33 AM
CharlieLed's Avatar
CharlieLed
Try these...Moog-K7293 for the uppers, the lowers look fairly common I am not sure where I got mine but they were available not too long ago.
Nate Daggy
Mar 5, 2018 08:58 AM
keyul
1997 - 2003 F150
Mar 4, 2018 08:15 AM
bbussman40
Nov 14, 2009 09:29 PM
caseys
Jan 1, 2004 04:45 PM
