Sponsored by: Auxito
Lower control arm removal question
Old Oct 24, 2016 | 12:43 PM
keyul's Avatar
keyul
2003 F150 5.4 4x4 Lariat FX4
Hello all, I am going to be replacing most of the components on my front end this week, upper & lower control arms, steering knuckles, inner & outer tie rods, ball joints, shocks, brakes.
When you go to remove the lower control arm, what needs to be done with the torsion bar? Do I need to Back the keep bolt off most of the way? Or do I need to use a torsion bar key holder?
Old Oct 24, 2016 | 05:08 PM
steve(ill)'s Avatar
steve(ill)
first off, I would question if the lower arm actually need replaced ? Are the mounts/ bushings that bad ? Second, if you do want to remove them, you need to back the torsion bar screws out completely to get all tension off the lower arms, then lower the arm down prior to removing the bolts.
Old Oct 24, 2016 | 10:11 PM
keyul's Avatar
keyul
Thanks, that's what I was thinking needed to be done.
And there's enough rust & scaling on the lower arms for me to warrant replacing them, especially with upgrading to larger tires next week. I ordered a Complete front end kit, should work out really nice!
Old Mar 3, 2018 | 07:21 PM
Nate Daggy's Avatar
Nate Daggy
Same issue
So I’ve unbolted the lower control arm it’s hanging by the torsion bar. So there shouldn’t be tension on it... so no need to do anything with the keys.. but I can’t seperate the control arm still. Did you end up cutting it or what?
Old Mar 4, 2018 | 08:15 AM
steve(ill)'s Avatar
steve(ill)
the arm is often rusted SOLID to the torsion bar.. You can heat / beat/ spray / push and HOPE..... or cut the arm without damaging the torsion bar......... then wire brush / surface grind the bar to fit the new arm.
Nate Daggy
Mar 5, 2018 08:58 AM
mcgowen980
1997 - 2003 F150
Nov 2, 2014 01:28 PM
RayKnappCarpentry
2004 - 2008 F150
Mar 20, 2012 08:04 AM
caseys
Jan 1, 2004 04:45 PM
