Fuel Filter Change #2
Old Jun 22, 2022 | 10:33 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
About 59,600 miles, going in for oil change #6 tomorrow, so did the 2nd fuel filter change myself this morning.
I'd let the Quick Lane do the fuel filter, but they get like $225 for the filter and R&R, which is outrageous since list on the filter is about $75 and it only takes about 15 minutes to change both filters.
Got my filter set off amazon, oem Motorcraft FD4641 for $59.
Took my time, about 30 minutes, including two hand washes and pics.
Ford really should make those connections on the secondary filter easier to R&R, plus the primary filter/separator on my 2012 that was a spin-on cartridge was easier than the current setup.
Rear tire up on ramp to make it easier to get under the truck...
And, the old filters, you can see some slightly dark areas on the panel filter, it was doing its job...
Set for another 30K miles...
Old Jun 22, 2022 | 12:18 PM
jcb206's Avatar
jcb206
Congrats. My manual says 22,500k miles for normal and 15k miles for severe duty. I change every 15,000 miles due to severe service.
I know you tow with your truck. Just curious why you chose 30,000 mile intervals?
Thanks. Also the dealership charged me $90 for fuel filter and change.
Old Jun 22, 2022 | 12:29 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Manual I downloaded for my 2022 online shows 30K intervals for fuel filter changes.
Old Jun 22, 2022 | 01:13 PM
4wd6.7L's Avatar
4wd6.7L
That would be under normal operating conditions. Do you primarily operate under any of the Special Operating Conditions listed, starting on page 631 of the 2022 manual?
Old Jun 22, 2022 | 01:21 PM
HRTKD's Avatar
HRTKD
2017 manual says 30k for normal operations, 15k for special operations (towing, extended idling or low speed operation).
Old Jun 22, 2022 | 01:31 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I don't pay much attention to that, I run almost 100% highway, least stressful miles there are.
I do tow a lot, but again almost 100% highway.
30K works for me, and I fully believe it could be extended without issue.
Old Jun 22, 2022 | 02:04 PM
jcb206's Avatar
jcb206
Not sure where I saw 22,500. 30k is in the manual. Odd.
Still doing 15k intervals since I fall under these conditions that say that 15k should be followed:
  • Sustained High-speed Driving at Gross Vehicle Weight Rating - Maximum Loaded Weight for Vehicle Operation
  • Towing a Trailer or Using a Car-top Carrier
  • Frequent or Extended Idling - Over 10 Minutes Per Hour of Normal Driving or Frequent Low-speed Operation if you use your Vehicle for Stationary Operation
  • Frequent Low-speed Operation, Consistent Heavy Traffic Under 25 mph (40 km/h) or Long Rush-hour Traffic
  • Operating in Dusty or Sandy Conditions (Such as Unpaved or Dusty Roads)
  • Using Biodiesel, up to and Including 20% Biodiesel (B20)
This last seems to be the defining one for me. I haven’t seen a pump without biofuel in 23k miles I have driven.
Not judging, your money, your truck. I was just curious why you would skip on this particular maintenance.
Old Jun 22, 2022 | 05:26 PM
B-ManFX4's Avatar
B-ManFX4
Looking at the picture of the old filter, I'd say the OP is spot on with his mileage assessment for the filter changes.
Old Jun 22, 2022 | 06:32 PM
HRTKD's Avatar
HRTKD
You never know until you open it up. There have been pictures posted of algae on the filter.
Old Jun 22, 2022 | 06:46 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Well, 60K miles in 10 months, mine doesn't sit still long enough for algae to form.
Old Jun 23, 2022 | 07:22 AM
Hunter23's Avatar
Hunter23
My 2019 got changed at 60 k first time and cut opened looked new . Depends on fuel quality
Old Jun 23, 2022 | 04:10 PM
mwebster22's Avatar
mwebster22
yikes, that’s $20,000 in fuel in less than a year!!!
ztodd377
15
May 29, 2021 10:12 AM
Jointasset
Mar 13, 2016 09:18 AM
crazer42
Apr 6, 2009 04:00 PM
jeaelectric
6.4L Power Stroke Diesel
Mar 4, 2009 06:54 AM
Uzumati
Nov 4, 2006 09:39 PM
