Detailing question
Old Nov 9, 2003 | 07:53 PM
jcb67's Avatar
jcb67
Detailing question
I have a black 1998 Expy with chips on the hood and the tail gate. These chips are filled with built up wax and it stands out like a sore thumb. The wax is settled in and I cant seem to get rid of the white residue buildup in the chips. Any suggestions?
John B.
1998 Expy
Alteeza chrome tails
Ractive Superflow Intake
Old Nov 9, 2003 | 08:23 PM
MisterCMK's Avatar
MisterCMK
Try using a toothpick to get to the wax.
Old Nov 9, 2003 | 11:42 PM
buzzard's Avatar
buzzard
Toothpick is good or a stiff toothbrush should work it loose.
Old Nov 10, 2003 | 03:18 AM
philrush's Avatar
philrush
this is where i recycle my old, used (some say "slightly used") tooth brushes.
They work great for detailing around places that wax hides.
Old Nov 10, 2003 | 01:04 PM
Aztrainer's Avatar
Aztrainer
toothbrush is the way to go. You may want to get the one with the rubberized dental pick, becuase they are often a good help in tight situation.
Just remember to keep this one out in the garage and lable it, or you may be getting yelled at for leaving your brush in the garage.
Old Nov 10, 2003 | 03:00 PM
1999XLT's Avatar
1999XLT
Stick with a toothpick. ESPECIALLY on a black paint job. If you go astray with the toothbrush you may scratch around the chip and make it more visible.
Old Nov 10, 2003 | 04:23 PM
jcb67's Avatar
jcb67
If I use a tooth brush to take the wax out, then I wont have the protection??? I do have a wax that has a black dye in it, I'm wondering if I should just use that? I'm very picky about wax products, But I'm wondering what I should do about these chips....
John B.
1998 Expy 4.6
Alteeza Chrome Tails
Old Nov 10, 2003 | 05:12 PM
buzzard's Avatar
buzzard
Fix the chips with touch-up paint available from your local ford stealership. Carefully mask around the affected area and dab a couple coats of touch-up in the chip. The key is to get the touch-up level as high as the existing paint. Let it dry a couple days, polish and wax.
Old Nov 12, 2003 | 01:42 PM
bingo begone's Avatar
bingo begone
try some of the color matching wax--get a color close to the vehicle color and it may blend better than the typical wax that tends to dry white in cracks or chips. I have found it reduces but not necessairily eliminates the problem.
dfishrmn88
Appearance & Dress-Up
Feb 2, 2008 09:42 PM
jcb67
May 16, 2004 07:46 PM
'95 Splash 4.0V6
Feb 11, 2004 08:39 PM
crettis89
Computer Chips & Tuners
Oct 25, 2003 04:38 PM
Pantera
Nov 8, 2001 10:03 PM
