Has anyone made their own battery boxes
I finally got all the wiring done for my Xantrax inverter. Now I have to add batteries which means a larger battery box. Has anyone made their own? I worked on a Newmar in which the owner did one out of wood that worked out well. Another option is for me to bend one up out of metal, but I am not crazy about having a metal battery box. I can buy one, but don't like what is in the catalog.
Steve
Steve
Steve - several on the Titanium forum made up battery boxes out of plywood when they installed multiple golf cart batteries. IIRC, fiberglass was used for internal protection. I had dual Gr 29 batteries and they were originally in some really trashed sealed boxes. These: Vented Battery Box | clancysoutdoors.com. They would have been great but the P.O. did a 'number' on them that negated any seal. I replaced them with conventional marine black boxes and added top vents to remove any accumulated and potentially explosive H2.
I have not yet, but plan to. I think the biggest considerations should be the surface or area you are planning to mount or place the box on and the ventilation requirements.
I plan to install at least 2 6v LifeLine AGM batteries which can be mounted in any orientation that works for the space and only requires venting in an overcharging situation. I will be using steel slotted angle iron for the braces and then 3/4" plywood for the walls. This will give me the ability to create a box that works for my needs and fits into the space I would like it to. Additionally, a cut off switch and any wiring could easily be installed into the box.
You can always put batteries on opposite sides of the front comp't as long as you use connection cables heavy enough (4AWG or better). That will break up a solid mass in one place
I bought a Century Plastics box for the upgrade on mine to a pair of golf cart batteries a week and a half ago. It is much more compact than the Noco boxes and fits the batteries well. They have a reasonable selection of boxes.
Battery Boxes (Battery Related Items) ~ All Battery Sales and Service
Century Plastics Ltd. - Totes, Bins and Containers
I used a couple of 1" wide straps to hold the lid on and built a custom vent using some 1.25" PVC and 1.5" ID Pool/Spa/Vacuum hose to attach to the factory vent through the front wall of the stock battery location. I still need to work something up to improve the seal on the box, but it worked well on my maiden voyage last week.
The plus about the AGM is that they are "maintenance free" and once they are installed they should not have to be messed with. That is in a perfect world of course. Ideally I would like to get a bank of lithium batteries, but would have to sell both of my arms on the black market in order to afford them.
Trojan T-105
https://www.batterystuff.com/batteri...batteries.html
LifeLine 6v
https://www.batterystuff.com/batteri...e/gpl-4ct.html
Trojan T-105
LifeLine 6v
I made my box out of 7/16" plywood which I glued with construction glue and also stapled with 3/4" staples. To seal the openings in the box, I just used putty tape pushed into the holes. This picture is without the top in place and the vent hose. You can see the inverter fuse without the fuse cover. Cables from the inverter and connecting the batteries are all 2/0.
Here it is with the cover in place.
This is the 2000 watt inverter install in the bay.
And here is the remote panel for the inverter and the solar controller.
Why did you choose to put the inverter in the bay instead of the storage compartment near the battery? I could see the bay location being safer from water/weather, but am curious about any other reasons.
Nice work on the box, it should do very well. Did you have to reinforce the floor of the storage compartment at all to support the weight? I have seen some of those storage areas where there is thin sheet metal and even a cut out for a generator.
Didn't need to reinforce floor. If those floors will carry a genset, I guarantee you it will carry an extra battery or three.
If you put inverter in battery compartment, you have to completely seal it from batteries as safety precaution, per manufacture's specific instructions. Have never seen one in battery bay.
No and I wouldn't use an RV manufacture as the template to whats right in these RV's. If it's done right there should be no problem.
Inverter/Batteries in compartment - Technical Tips and Tricks - Escapees Discussion Forum
