Overheated…
Old Jun 17, 2022 | 08:02 PM
85F250Diesel's Avatar
85F250Diesel
Overheated…
I replaced my rad a couple weeks ago and it completely failed on me today!! Puked all the coolant out through a failed plug on the drivers top corner.
The EOT had reached 300F when I noticed and pulled over. It fired right up after sitting for a half hour waiting for my wife to arrive with water. Poured 5 gallons in and it cooled right down and drove perfect 5 miles home.
I plan to replace rad with a mishimoto, and change the oil. Anything else I should consider checking out? I wondered about the water pump running dry, I figured I might swap that out too.
VERY unhappy with my purchase right now.
Old Jun 17, 2022 | 08:12 PM
97-psd's Avatar
97-psd
Sorry about your luck. I wouldn’ t worry about the pump. The hearing is sealed and doesn’t need the water. What oil are you running?
Old Jun 17, 2022 | 08:55 PM
85F250Diesel
Rotella T4 15-40
On edit, 6/29/22: I found the root cause of the overheating issue was the water pump failed and lost coolant through the weephole, causing a boiling condition which overpressurized the system, and blew the radiator. New waterpump, motorcraft Tstat, oil change, and I am back trucking.
Orpackrat
33
Jul 30, 2014 12:01 PM
jkidd_39
Oct 12, 2009 11:37 PM
tboss619
Jul 6, 2009 09:54 PM
Saguaro_7.3
Nov 23, 2005 09:22 PM
Cephus
Aerostar
Jul 3, 2005 05:42 PM
