Coolant Flush Troubles
Old Oct 12, 2009 | 07:18 PM
jkidd_39's Avatar
jkidd_39
Did a water pump/coolant flush today.
New thermostat and upper neck from Ford.
Pulled the radator plug and driver side coolant plug. (Did not pull pass. side so I didn't soak my starter.
Put the plug back in and filled it up w/ water and then pulled the plug and drained it. After filling it up it was clear water coming out.
Pulled water pump, put new water pump, thermostat and neck on.
Added 4 gallons of Motorcraft ELC coolant and almost a full gallon of distilled water.
Warmed truck up and took it for a 10 mile drive. Let it idle for an hour.
Now the problem... the thermostat will not open.. I cannot put anymore water in.
What the H!!
Help anyone?
Thanks all
Old Oct 12, 2009 | 07:26 PM
agg_bagg's Avatar
agg_bagg
its been a while since i have done one of these so i cant remember how it goes in but is there any way that you have the T-stat in backwards.
Old Oct 12, 2009 | 07:33 PM
tdpower's Avatar
tdpower
What Jeron said...Also try to turn on your heater. That should help if just air trapped in it.
Old Oct 12, 2009 | 07:34 PM
onelionhunter's Avatar
onelionhunter
Faulty t-stat?
I have heard alot of the aftermarket t-stats are bad out of the package. believe I read where someone here tested theres by dropping it in a pot of boiling water to see if it opens. That would be my best guess.
Tom
Old Oct 12, 2009 | 08:45 PM
mueckster's Avatar
mueckster
I always leave the heater hose off the top of the waterpump to let the air escape while filling the reservoir. I connect the hose when the coolant just starts coming out. When I fill it up and let it warm up, I usually don't have to add much at all.
Did the truck try to overheat or are you just concerned with not getting any more coolant in there?
Old Oct 12, 2009 | 09:34 PM
jkidd_39's Avatar
jkidd_39
It has not tried to over heated.. it got to normal temp and hasn't moved since.
Ford wouldn't have given me a short stem thermostat would they?
Old Oct 12, 2009 | 09:40 PM
agg_bagg's Avatar
agg_bagg
if it doesn't overheat then i would say that your t-stat is opening. you would heat up pretty quick if it wasn't. just keep an eye on it and keep it topped off and i think you will be fine.
Old Oct 12, 2009 | 09:46 PM
jkidd_39's Avatar
jkidd_39
Isn't it a problem that I have 4 gallons of concentrate ELC coolant and only 1 gallon of water?
Old Oct 12, 2009 | 09:50 PM
mueckster's Avatar
mueckster
The thermostat would still open, even if it was a short stem. It just wouldn't close the internal bypass hole in the W/P when it fully opened. What part number did they give you?
Old Oct 12, 2009 | 09:52 PM
mueckster's Avatar
mueckster
Not if there was some water already trapped in the block from not draining the passenger side. Even when draining both sides of the block, I don't recall being able to get a full 8 gallons in there. I couldn't account for what stayed in the block.
Old Oct 12, 2009 | 11:37 PM
triskit16's Avatar
triskit16
Theres definitely still some in there from not draining the passenger side. I went through the same deal, but I just kept 2 gallons of distilled water in the truck and checked it once a day to make sure the level hadn't dropped.
