Transmission temp gage
Old Jun 16, 2022 | 06:34 AM
Rick1025's Avatar
Rick1025
I recently purchased a transmission temperature gage for my 2002 E350/4r100 transmission. The directions say the probe/sending unit can be installed in the test port on the side of the transmission,in the line to the cooler,or to install a bung in the pan. Which is preferable? Does the test port allow fluid to flow past it? or is it mainly for pressure testing? thanks for any replies.
Old Jun 16, 2022 | 07:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I recommend the test port. That will give an accurate reading of the internal trans temperatures.
When I was a transmission engineer at Ford I had many transmissions that were instrumented for temperatures. I had thermocouples all over the insides. I also always had one in the test port. The test port is generally hotter than the pan temperature, and cooler than the outlet to the cooler. It is a good average temperature to indicate how the transmission handles the heat.
Old Jun 17, 2022 | 05:31 PM
Rick1025's Avatar
Rick1025
Thanks for the reply
nwertz555
Aug 20, 2014 05:35 AM
beerdude41867
Jul 10, 2008 07:45 AM
Pigeon
Aug 27, 2006 05:57 PM
Ultraute
Jun 27, 2005 10:25 PM
