Help Setting rear height/load sensing valve
Old Jun 15, 2022 | 07:11 AM
Phil527's Avatar
Phil527
I needed to replace the hose on my rear axle to the height/load sensing valve and figured I would remove it, clean it up and paint it while I was waiting for the hose to arrive.
Unfortunately, I did not notice there was a flat on the shaft part until after I got it out. The bracket attaches to the knurled section of the shaft - so I am not sure how to set the correct initial position of the valve. My Ford Shop manual covers the installation of the unit, but does not mention anything about the orientation of the valve shaft when initially attaching the actuating arm. There is no other key/index on the shaft or arm so my only thought are that the flat must be what is used? Flat up? Flat Front?
From the looks in my manual it is valve assembly 2B547
1986 F250
Thanks,
Phil
Old Jun 15, 2022 | 01:01 PM
Phil527's Avatar
Phil527
pic of operational unit?
Another thought - if anyone has one of these and is willing to slide under their truck and take a pic it would be a big help. The flat should be visible between the actuating arm and the unit.
Phil
Old Jun 15, 2022 | 08:06 PM
BigBlue2's Avatar
BigBlue2
looking straight up on a 86 F250 HD
Old Jun 16, 2022 | 06:05 AM
Phil527's Avatar
Phil527
AWESOME, Than you !
Looks like your flat is pointing down when looking up.
Old Jun 16, 2022 | 09:00 AM
BigBlue2's Avatar
BigBlue2
Originally Posted by Phil527
AWESOME, Than you !
Yes, the flat is not quite parallel to the level, but pointing down is what I see.
d3ryl
13
May 20, 2022 12:59 PM
Homegrown1
6.2L V8
Apr 1, 2022 01:44 PM
ynot321AB1
Sep 22, 2021 08:01 PM
rtcapo
Jul 27, 2021 08:12 AM
kh0432
Nov 10, 2019 10:19 AM
