2014+ Transit 2014+ full size Ford Transit Van, Wagon, Cutaway and Chassis-Cab
Check engine light
Old Jun 14, 2022 | 08:52 PM
NHNRS's Avatar
NHNRS
Trailering
Check engine light
Having an odd issue today, I filled up at Shell and had a couple of errands to run. On the way back I had a moderate hill to go up - suddenly the van started running rough and dropped into limp mode and would not climb the hill. I turned off the engine and then restarted it, it ran fine and went up the hill like normal. I have a Blue Driver so I pulled the codes and came up with this:
B10AC-4A
Driver Seat Track Position Switch Cross-Link to Another Sensor: Incorrect Component
Installed
I cleared the code and went to another moderate hill to see if it would happen again. It did and the same code was logged.
No work has been done recently and the seat track switch is the original that came with the van. Blue Driver does say the "cause" may or may not be correct. They log it in the "Generic / Body Electronic Module (TPMS / PATS) Code section. Most online searches turn up references to the cruise control for that code but it seems to work fine. Has anyone run into this before?
Thanks!
Bob
superkonr
17
Dec 11, 2021 09:05 PM
SCarolina
6.2L V8
Aug 28, 2020 07:03 PM
menesesjesse
1978 - 1996 Big Bronco
Sep 29, 2011 06:30 PM
R-T0r21on
6.4L Power Stroke Diesel
Jul 30, 2009 09:40 PM
Blinko
Sep 23, 2001 03:30 PM
