PCM trouble?
Old Jun 13, 2022 | 09:16 AM
llama's Avatar
llama
PCM trouble?
Hello alll. I have an issue with my 94. I recently removed the engine for new gaskets and heads. After reinstall it started right up for a quick test of function,~3 seconds. Then it sat over weekend while I was out of town. Now it shows low voltage codes for tps, maf, and charcoal canister. It will occasionally start and then die. I have 40 pounds fuel pressure, good spark.
One problem I have found is the tps signal return shows no voltage at any time. The tps signal return shows continuity to ground. Is this normal?
I have gone ahead and removed the pcm and opened it up. It does have some corrosion on the inside wall.
Any ideas?
1994 f150 2wd 5.0
Old Jun 13, 2022 | 09:36 AM
rla2005's Avatar
rla2005
What are the codes by number and when were they displayed?
Completely normal. Signal Return is a dedicated path to ground for several key sensors. Did you measure VREF with reference to ground?
Old Jun 13, 2022 | 10:42 AM
llama's Avatar
llama
Codes are 122, 565, 157,35. This is with koeo. I do have 5 volts on VREF on 12 volts on the ground.
Old Jun 13, 2022 | 10:47 AM
rla2005's Avatar
rla2005
There is never a mix of two AND three it's one or the other. Your truck displays three digit codes only. I assume you are counting flashes to run the Key One Engine Off (KOEO) tests and Stored Code display?
Old Jun 13, 2022 | 10:54 AM
llama's Avatar
llama
I was using an obdI reader. it displayed the 35 as well as the others.
Old Jun 13, 2022 | 11:05 AM
rla2005's Avatar
rla2005
Try running the KOEO tests and Stored Code display again. As I previously stated you will never get a mix of two AND three digit codes. It just does not happen. What code reader are you using?
Old Jun 13, 2022 | 11:48 AM
llama's Avatar
llama
Will do tonight. FORD OBD 1 code reader 1981-1995, it doesn't have a brand. Thank you for your help.
Old Jun 13, 2022 | 11:57 AM
rla2005's Avatar
rla2005
If that no name brand reader is still displaying Code 35 I suggest you change it's battery then retry again. If you still get Code 35 chuck it in the trash can then run the tests/code display using a jumper and count flashes.
Old Jun 13, 2022 | 11:58 AM
llama's Avatar
llama
I took pictures of the codes as they came up. Friday at 6;40pm I got, 35 then 565 then122 then 157. I understand when you say it can't, but it did. I am assuming since I removed the pcm all previous codes will be erased. The 35 I believe relates to the smog pump. Smog pump has been removed.
Old Jun 14, 2022 | 08:07 AM
llama's Avatar
llama
I checked the codes last night. I got 565, 122,157,111.I may have miss stated yesterday. When i stated the signal return had ground continuity. It is the TP wire that has a beginning reference of ~1 volt and goes up to ~4.9 volts with throttle wide open. This is the black wire on the TPS. It has no voltage and does show continuity to ground. Sorry if I used the wrong terminology yesterday..
Old Jun 14, 2022 | 01:53 PM
rla2005's Avatar
rla2005
The black wire is Signal return.
1988-1991 TPS Wire Colors
VREF - Orange/White
TP SIG - Dark Green/Light Green
SIG RTN - Black/White (My 1990 is actually Red/Gray)
1992-1996 TPS Wire Colors
VREF - Brown/White
TP SIG - Gray/White
SIG RTN -Gray/Red
Motorcraft TPS Wire Colors
VREF - Orange
TP SIG - Green
SIG RTN - Black
Code 122: (KOEO) TPS circuit below minimum 0.6 volts.
Code 157: (CM) MAF sensor went below 0.4 volts during the last 80 warm-up cycles.
Code 565: Canister purge circuit failure
Verify the CANP solenoid is plugged in
Code 111: System Pass
Uncle JimBod
Nov 23, 2022 04:31 PM
EBStender
Sep 4, 2016 02:05 AM
RIKIL
Jan 24, 2013 02:57 PM
jkinghorn6.0
Feb 2, 2012 07:11 AM
bb454s
18
Jan 8, 2011 09:44 AM
