Master Window Switch
Old Jun 11, 2022 | 12:57 AM
VegiePower's Avatar
VegiePower
Hello. I have an issue with my windows. The windows have periodically stopped working. Occasionally these is a buzzing in the switch. A window may get stuck and when it does none of the other windows work either. Figured it was a switch issue so bought a new switch, installed it and it worked for a few minutes and then it stopped working too. No buzzing yet. Is there a relay or is it likely a faulty wire somewhere.....
Thanks
Old Jun 11, 2022 | 03:13 PM
Tunafish389's Avatar
Tunafish389
In section 100-1 of the attached off is the wiring diagram for the windows. There are a few relay before the driver switch and the easiest way to test if these is your issue is to test fuse 62. If you have power to this fuse when you have issues then the relays are good and issue is else where.
If relays are good then next will be testing power to the driver switch which will be a light blue with black strip wire. You should have 12v here also, if not then you have a issue with the wire (assuming you had 12v to fuse 62).
If all that test good than you have another bad driver door switch.
ShamrockRacing
Jul 19, 2021 05:54 AM
Gwilkrrs
Jun 8, 2021 01:57 PM
Krazyhorse93
Nov 13, 2017 08:22 PM
Dick7.3
Feb 12, 2007 05:22 PM
amm888
Jan 23, 2006 07:01 PM
