Coating the roof with bed-liner
This is something I’ve been considering for some time now. My first thought was going black.
There are two reasons I’m considering this; as a sound and thermal insulator, and to seal that channel so I don’t have to worry about rust.
The material goes on ~1/8” and it is somewhat flexible so it shouldn’t crack. The only negative I could think of is black might not be the best choice. Then I learned it could be colored, even color matched. My thought is, why hide it? Make it a color that would compliment, like a beige something like the cladding.
So here’s what I did; I took a few pictures and drew the liner to see what it might look like.
I welcome opinions, concerns, and compliments. 🤣
The following users liked this post:
I did this to mine and love it. I did not want to have to climb up there and wax and clean all the time. I hated the rack up there. Had the rack removed sanded down and filled then primed and had Bullet Liner applied up there leaving about 4-6" around the 3 sides. Leaves enough room to mount an aftermarket roof rack if I want on in the future. Here are a couple pictures. Paid approx $1400. to get mine done.
If you have a bodyshop that's willing to work with you, there are tintable bedliners that you can get color matched.
https://store.sprayliningandcoatings...bed-liner-kit/
I'm not very good at color schemes so aesthetic criticisms are welcome.
Does seem a little quieter. Since my paint job was really nice I did not want to change the color of the top. Just wanted a maintenance free top. Mine has a Zeibart sprayed undercarriage in 2021 and zero rust, it makes a nice match. Mine has 85,000 miles currently and I live in Eastern Virginia, these two should make this truck last for a long time. I was really concerned about future rust around the low roof rack, which is why I had it taken off. Lots of writeups on how they would rust. I found the rack to be difficult to work with. Have done a little research on aftermarket racks and there are a few nice ones and some writeups on making one from scratch. If I end up keeping the truck, I'm going to go this route. Wife is trying to get me to get a Monaco Dynasty Class A RV instead of buying a 30" Airstream which was one of the reason we bought the Excursion.
Oops, my bad. I misread your post thinking it was already done.
I used Raptor liner in my wheel well when I did the dog leg. Easy to spray but messy, black but tintable options as well. You can stack it up thick like seen here or you can just apply a couple of good wet coats and call it good. I was really impressed with how it came out and will be using it again. Preparation is everything. Seems super durable. Been down gravel roads and no chips. I actually have some for my front bumper but have several other things to do before that.
.... Then I learned it could be colored, even color matched. ....
Also, had the swim step of our boat done 15 years ago.
There is a shop near us that does truck beds, but a lot of their business is trailer/RV roofs.
I was told there is a slightly different formulation for trailers, probably because it's being sprayed on wood.
The base material is clear and it's colored with paint mixed in.
reamer
09-29-2019 08:08 PM
swampthang
20
02-22-2014 09:11 AM
wyckedcombo17
195
05-15-2012 11:06 PM
