I have a 2008 5.4 Lincoln Navigator that Idles around 2000/2100 when in park or neutral. Its has been sitting for almost 3 years with transmission problems. I finally put a used transmission in and seems to be all good except the high idle. It runs and drives fine down the road and when in gear it idles around 800/900. Could the used transmission be causing the high idle issue?? No codes come up.
