Sponsored by: Auxito
Engine, RPM bounce / surge
Old Nov 9, 2007 | 07:52 AM
redsodie's Avatar
redsodie
Morning All<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I’m sure this has been discussed before (no hits when searched)<o></o>
I have an 02 - 5.4<o></o>
Occasionally I will get a brief engine rev, or rpm surge/bounce when stopped at light. It only happens when I first start out (cold) and it only happens for about 15-20 seconds. Its not a slipping trans, cause I have to stand extra hard on brake to keep truck still…any ideas<o></o>
Old Nov 9, 2007 | 08:55 AM
LxMan1's Avatar
LxMan1
Sounds like you have a sticking IAC valve. (Idle Air Control). Sometimes it can be removed and cleaned and work ok, sometimes it just needs to be replaced.
It is located here https://www.ford-trucks.com/user_gal...=99254&width=2
https://www.ford-trucks.com/user_gal...=99255&width=2
Old Nov 9, 2007 | 09:20 AM
redsodie's Avatar
redsodie
Does the fact that I have no CEL codes seem strange with this idle problem? Esspecially if its a sticking (carboned up) IAC?
I will try and clean it this weekend, giving that a try first.
thanks for the suggestion
Old Nov 9, 2007 | 01:42 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Nope, CEL won't come one...My truck did that once (coupled with low idle while at a stop ~450-500RPM), and I replaced the IAC, but it never helped my low idle issues. Bought a PCV valve, but it was the wrong one. Funny thing is, my truck seems to have cured itself If it acts up again, I'll get the correct PCV valve and replace it.
2EXP & 1EXC
Mar 17, 2008 02:44 PM
RV-Dean
Feb 26, 2008 04:38 PM
Residence
New Member Introductions
Nov 6, 2007 08:15 PM
ccelectric
25
Apr 23, 2007 06:59 PM
kl67
Feb 14, 2007 05:14 AM
