ATS TURBO RECOMMENDATIONS
Old Jun 2, 2022 | 01:30 PM
BaCK CRACKER's Avatar
BaCK CRACKER
1st Gear
I bought a used ATS aurora turbo 3000 for my F250 6.0 with 200,000 miles on it, without tunes and just normal bulletproofing. This turbo I bought came with up pipes and a new pedestal. Since it’s a fixed-vein turbo replacing a variable geometry one, ATS supplies a turbo control inline interrupt pass-through module that breaks into the MAP sensor line. The problem is I do not have this interrupt pass-through module and I live in California and can not pass smog with a MAP sensor code. They no longer sell this device. My question is can a Tuner like an SCT fix the map senor issue?. What would you do in my situation? I was looking for better towing power. Thanks
Old Jun 5, 2022 | 08:22 AM
Byrd.Dog's Avatar
Byrd.Dog
You will need to have a custom tune written to get this turbo to run right. You will also need an SCT, or similar tuner to load the file onto the PCM.
Old Jun 5, 2022 | 12:44 PM
Motohead911's Avatar
Motohead911
I live in California also, with a tune for a fixed vane turbo, good luck passing smog. The Calid and CVN will not match what the state's system expects and daily you for "Modified Software"
Also, why change to a fixed vane?
Old Jun 5, 2022 | 06:58 PM
AK4x4's Avatar
AK4x4
I recommend that you sell what you bought, then call KC turbo and buy the variable geometry turbo they recommend for your application/usage. However, unless you plan to move, you need to ensure that all parts are IM approved "in California" or have a valid CARB EO number before you install them. Russ
02GrayPowerStroke
Feb 17, 2010 02:06 PM
4bigred
Nov 8, 2008 01:38 PM
emmagator
Oct 14, 2007 08:13 AM
TheDuke
Sep 1, 2007 03:33 PM
billyboy
May 22, 2005 11:03 AM
