Ignition timing jumping around
Old Jun 2, 2022 | 09:45 AM
Stokes76's Avatar
Stokes76
3rd Gear
Howdy
Ive had this problem since last week. If I start the truck (‘94, 4.9 m5od 4x4) from cold, it starts VERY quickly, much quicker than it ever has. It seems to run fine, if not a little lean. If I turn the engine off and start it again, it takes more cranks and then sputters and I get terrible acceleration. If I cut the engine off and then wait an hour, it’s fine again.
I changed the ignition control module and that seemed to fix it for a day, but now it’s happening consistently.
I guess I should get a code reader, but does this situation sound familiar to anyone?
Old Jun 2, 2022 | 10:54 AM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by Stokes76
Howdy
Is your timing jumping...
Old Jun 2, 2022 | 11:32 AM
Stokes76's Avatar
Stokes76
3rd Gear
While I’m driving I can’t notice any change in timing. The change happens when I turn the engine off and on again. Then it’s consistently rough, unless I turn it off and let it sit an hour
Old Jun 2, 2022 | 11:33 AM
R&RFord's Avatar
R&RFord
Get a fuel pressure gauge and check for leaky injector/s.
Old Jun 2, 2022 | 01:05 PM
sandymane's Avatar
sandymane
If you would like to run diagnostic codes here is how to do it. A paper clip can serve as a jumper. Only run the key on engine off test. KOEO. You will also need to depress the clutch the entire test to get your codes.
sasquatch999
29
Feb 25, 2008 12:04 AM
Judson4.9L
Dec 6, 2005 07:28 PM
jake1475
1978 - 1996 Big Bronco
Aug 18, 2004 07:53 PM
1988ford
May 4, 2003 10:14 PM
chulsey12
Dec 11, 2002 11:36 AM
