ignition module
Old May 4, 2003 | 08:37 PM
1988ford's Avatar
1988ford
ignition module
I have a 1988 302 and drove my truck for a while, shut it off, then it would not start again for a couple of hours. While it would not start it would only turn over and there was no spark at all. Went to oriely's and bought a new ignition module and had to pull out the distriutor to replace it. Starts fine every time now but misses really bad when taking off. What could this be. Bad ignition module??? or something else? I would appreciate it if someone could help me out. thanks.
Old May 4, 2003 | 10:14 PM
eckart's Avatar
eckart
ignition module
Id check the timing first. Don't forget to pull the spout conector before you do.
