Transmission
Old May 29, 2022 | 03:26 PM
Bearhugger1933's Avatar
Bearhugger1933
Transmission
2001 f250 cc 3.55 gears,I have three questions,first I have had this truck for about 6 months,first time to pull 26 foot tt at about 65 mph rolling hills it kept kicking out of over drive so I locked it out,rpm jumper to about 2700 rpm,will it hurt to run at that rpm for a long trip,transmission temp stayed good ,abou 185 deg, second question, when I back up a small incline or upon a leveling board the motor will bog down has a hard time pulling upon the board gust like if you were taking off in a high gear,forgot the third question, hope Mark will jump in on this one,Thanks guys,this old man needs some help. here
Old May 29, 2022 | 03:38 PM
FinnishStroker's Avatar
FinnishStroker
7.3 can run 3000rpm all day long.
If you have 4x4,back with transfercase in low..?
Old May 29, 2022 | 04:18 PM
Bearhugger1933
2 wheel drive
Old May 29, 2022 | 04:41 PM
Mickey Bitsko's Avatar
Mickey Bitsko
Reverse gear is pretty weak, make the incline very gradual.
Old May 30, 2022 | 06:53 PM
Bearhugger1933
That is the only way this truck will go up in reverse pushing a 5000 lb travel trailer,bog down.
Old May 30, 2022 | 09:21 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
"Bogging" in reverse is usually the torque converter clutch partially applying due to a lack of pressure caused by low fluid, filter tube leak, or internal pressure leak from worn sealing rings or damaged piston seals.
Old May 31, 2022 | 01:52 AM
udsuth78's Avatar
udsuth78
This will hurt your mpg a bit I'm sure. Might price a gear swap to some 3.73 or even 4.10. Would probably cure the OD problem and help your bogging in reverse too. I doubt it would take many $5+ gallons of diesel to justify the the swap
Old May 31, 2022 | 01:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Ford never made that. Either someone swapped the gears, or you have it wrong. If it is a single rear wheel it is a 3.73:1 axle. If it is a dually it could be a 3.73:1 or a 4.10:1.
Leadfeather
Oct 18, 2018 11:29 PM
bamcq
6.7L Power Stroke Diesel
Mar 27, 2017 10:28 AM
nico963
Dec 24, 2006 01:06 AM
Robbgt
Feb 26, 2005 07:28 PM
BCBen
Apr 16, 2004 07:40 AM
