Help Identifying Vacuum Advance Unit
I bought one of those A-Cardone Distributors from eBay with Points. Now I need to replace the Vacuum Canister and there are no Parts available for it. I have looked at every year replacement for anything close and came up with Nothing. So I purchased a Motocraft 12127 distributor that has the same Canister on it. On My Picture the one on the left is what I need to Know and the one on the right is what is sold as replacement. I did find a DD-191 canister that is the same except it has the screw in vacuum line. Somebody must make this part and I'm sure I'm not the only person to have this issue ... Anybody ?
Can anyone ID the Left Canister ?
The first one would not even bolt to the dist. body as the holes were way off.
The store did not even know what it was for
The next one looked like it would bolt up but did not have the Allen adjustment like the factory one did so I did not get it as mine was still good.
Could the one on the right be fore a v8? It also looks like it will not bolt up.
So what are we working on as your sig is a 86 and would not have points or vacuum advance as it would be a feed back system.
Dave ----
I do Have an '86 truck but did replace with a points dizzy. I'm not at all interested in the feedback and control box setup and changed it years ago. So My engine is basically a 1968-1972 as far as parts suppliers go.
When I was trying to replace mine I was using 1981 as that is what my truck is.
I also was going thru O'Reilly's auto parts as they are with in walking if I have to but seam to be pretty good on ordering parts when needed.
I wish I knew the part number of the 2nd one I got as it looked like it might of bolted up.
The only reason why I did not get it was it could not be adjusted and mine stilled worked.
Thats all I got sorry
Dave ----
https://www.oreillyauto.com/shop/b/i...vacuum+advance
Did you say you have a tag on the dist. you could use?
Dave ----
I emailed Cardone so we'll happens
I replied asking if it's being repaired then why can't you just sell me one of the parts you'd be using to repair mine?
