Vacuum canister replacement
Old Mar 29, 2022 | 08:47 AM
Andrew Losinno's Avatar
Andrew Losinno
Hi all, I’ve been wanting to redo my vacuum system since it seems almost every time I go to work on it a vacuum like winds up crumbling apart and want to replace the coffee can vacuum canister but haven’t been able to find anything online for it. I find them in junk yards but they got pin holes in them. Anyone got any fixes or known places where I can get a new one? Thanks.
Old Mar 29, 2022 | 08:50 AM
DaBrkddy's Avatar
DaBrkddy
My vacuum canister developed rust holes as well. Instead of trying to find a replacement, I just put check valves in the related vacuum lines. Everything seems to function correctly since then.
Old Mar 29, 2022 | 09:37 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Used plastic reservoir from the junkyard or try a new one from LMC
Adding check valves in the vacuum lines is interesting. Not what I would have done. I would have replaced the reservoir.
Old Mar 29, 2022 | 09:40 AM
rla2005's Avatar
rla2005
Look at F250s and F350s. They have a dual diaphragm plastic reservoir in them. Why Ford stuck the metal coffee can on the F150/Bronco is beyond me.
Old Mar 29, 2022 | 04:45 PM
Andrew Losinno
I need to completely replace mine, I was leaning on the plenum and cracked the two red lines that connect to the top of the plenum and it broke into like 3 pieces so I’m going with silicone replacements.
Old Mar 29, 2022 | 04:50 PM
Andrew Losinno
I’ll have to keep my eyes peeled for a plastic one at my junkyard, lmc didn’t have the metal can in stock, thanks for the tip though
Old Mar 29, 2022 | 06:49 PM
spurredon's Avatar
spurredon
They are the same size as a tomato juice can or some other juices. I bought a can of tomato juice, punched a hole in the center of the top and drained it out and then used a hole saw to cut the hole needed for the fitting from the old can. Since the old can is junk, just start cutting it up until you can get close enough to get the top panel off. The fitting is held in place with a separate ring of plastic on the back side you will carefully need to pry apart. Then it is a matter of painting the can and putting it all back together. If you end up not getting the inside ring off in one piece, you can just silicone the fitting in place. When you are finished it looks like factory!
Old Mar 29, 2022 | 07:39 PM
torq'ta 5 8's Avatar
torq'ta 5 8
My can was fine, the check valve inside on the other hand, gave up the ghost, I got the little softball, instead, and as the man falling out the 10 story window said going by each floor, so far, so good.
Old Mar 29, 2022 | 10:40 PM
Scndsin's Avatar
Scndsin
1st gen Escapes have a pill shaped tank that I believe is the same as SN95 Mustangs. Has a bracket too.
I spent $5 maybe?
erikkloss
Jan 20, 2017 04:00 PM
robmurray65
Large Truck
Sep 10, 2009 03:05 AM
79'r overhere
Aug 21, 2006 01:00 PM
