Sponsored by: Real Truck
Need injector help
Old May 26, 2022 | 05:21 PM
Big-1's Avatar
Big-1
Need injector help
Okay gents, I need your help. I have a 2007 F350 with 330,000 miles on it. About a year ago, I replaced injector 1,3,5 & 7, because #3 was bad. My mechanic said that since we were gonna open up the engine, might as well do 1/2 of them and then the next time, if one on the other side goes bad, replace the other 4, and save tons on labor. Okay, several months ago, injector #3 was causing problems and he changed #3 out and warrantied it. Last Thursday, something shorted out #3 again. They don't think I could get 2 bad ones in a row, and they are talking about the changing out the wiring harness and if that didn't do it, they are talking about changing a part that would cost $600.00. They said it is a part that tells the injectors when to fire. Anybody got an idea of what could be causing the injector to fry?
Thanks in advance
Old May 26, 2022 | 07:41 PM
m-chan68's Avatar
m-chan68
The part being described is the FICM (Fuel Injector Control Module). It is the silver finned box mounted on the driver side bank of cylinders in the engine compartment. They are pretty common to fail. But to diagnose, requires use of a scan tool. Where your injectors being sourced from? Ford/Motorcraft or aftermarket? I wouldn't install anything other than Ford/Motorcraft. Especially when it comes to injectors.
Old May 26, 2022 | 07:45 PM
Big-1's Avatar
Big-1
Injectors come from a Ford Dealer. Mullinax. Is it expected to fail after 330,000 miles?
Old May 26, 2022 | 07:47 PM
m-chan68's Avatar
m-chan68
330,000 is a lot of miles. I'm surprised more of them haven't failed, at that high of mileage.
Old May 26, 2022 | 07:48 PM
Big-1's Avatar
Big-1
As a master tech, would you recommend i get them to change the wiring harness AND the FICM?
Old May 26, 2022 | 07:50 PM
m-chan68's Avatar
m-chan68
At that mileage, it definitely wouldn't hurt, provided you are intent on keeping it a couple of years, and there's no other issues with the engine.
Old May 26, 2022 | 07:52 PM
Big-1's Avatar
Big-1
My mechanic, (who is great) cannot figure out what is blowing the #3 injector. He's racking his brain and cannot come up with what to do.
Old May 26, 2022 | 08:19 PM
m-chan68's Avatar
m-chan68
A bad driver in the FICM could possibly do it.
Old May 27, 2022 | 11:23 AM
bwguardian's Avatar
bwguardian
You can have that FICM rebuilt instead of buying new...
Old May 27, 2022 | 02:08 PM
FiveOJester's Avatar
FiveOJester
At this mileage I might just replace both the FICM and injector harness. The parts aren't that much money, especially if your frying injectors.
Has your mechanic inspected the injector harness?
Also injector #3 is probably one of the hardest to plug in as it's got the main harness with a bunch of branches right above it. He's making sure the connection is securely made?
Rebuilt FICM $300:
https://circuitboardmedics.com/2003-...ficm-exchange/
Injector harness $200:
https://www.riffraffdiesel.com/fuel-...ss-05-07-6-0l/
Injector #3 location:
Old May 31, 2022 | 08:07 PM
Big-1's Avatar
Big-1
Here is what we settled on. He is going to change out the FICM and the wiring harness for that side of the injectors. He cannot figure out what and why that #3 injector is getting a pulse that is frying it.
I'll keep you folks posted.
Thank you
Old Jun 2, 2022 | 11:05 AM
Guy on the farm's Avatar
Guy on the farm
You could get your harness from FORD PARTS GIANT they have great prices and for the FICM I look at warranty I think Bullet Proof has the best.
Old Jun 3, 2022 | 07:00 PM
Big-1's Avatar
Big-1
Okay, here is what was found. Lifter failed on #3. It let the pushrod drop and kicked the rocker arm off. Mechanic is prescribing a reman. He will replace everything except the block, crank and heads. New pistons and upgrade camshaft. Between $12,000 and $13,500.00. Any input or ideas? Is it time to get rid of this truck?
Thank you,
bwguardian
18
May 28, 2022 04:17 PM
Dutter65
Jan 7, 2014 04:00 PM
1991 F Super Duty
15
Jun 10, 2013 09:28 PM
pskelton
Jul 28, 2008 05:31 PM
Rick2001
Feb 7, 2007 03:21 PM
