Injector internals
Old May 22, 2022 | 11:28 AM
bwguardian's Avatar
bwguardian
Injector internals
Is there anything within an oem factory injector that can go bad sitting on the shelf for awhile. I recall seeing some information relative to them having internal o-rings, but that has been the only reference I've seen of such.
Old May 22, 2022 | 11:42 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If the injector is properly lubricated and in a container or plastic bag, it has a shelf life of ~24 months that it can be put into service. After that, it may need to be inspected.
I was told this by a well known injector builder that participates on here from time to time.
I was inquiring because I had thoughts of buying some new/reman injectors and put them on the shelf as my injectors are at 266,000 miles.
I decided to run mine until they die, which may be another 100 - 200 thousand miles.
I hope this helps.
Old May 22, 2022 | 11:50 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Friday, I sold/installed a new-in-box set of remans that I purchased in May of 20.
Runs like a top!
Old May 22, 2022 | 12:43 PM
ESwift's Avatar
ESwift
CNCFAB
I still wonder what the difference is if they sit sealed on a shelf with testing fluid in them, vs sitting in a truck with diesel in them, being exposed to heat and running conditions… I would prefer for them not to sit a long time, but I a not convinced that would actually hurt them
Old May 22, 2022 | 01:12 PM
Walleye Hunter's Avatar
Walleye Hunter
The only thing that I could see being an issue would be the flexibility of the external O-rings for installation and sealing. If they are still soft and pliable, I wouldn't think twice about the age.
Old May 22, 2022 | 03:43 PM
bwguardian's Avatar
bwguardian
Thanks guys, I have a complete set of sticks from an F550 that had 35k-40k on the clock that were pulled years ago and have set on the shelf since. I also have the oem valve gaskets with harnesses and glow plugs from the same truck. My intent is to possibly put them in the Excursion and they would at the very least get new o-rings, but maybe also get a few or all of them tested. I just don't see how they could go bad...other than obvious metal deterioration...but there are people on this site that know more about this than I do...
Old May 22, 2022 | 05:13 PM
FinnishStroker's Avatar
FinnishStroker
Swapping external o-rings in known-to-be-good injectors is a no brainer to me.
But doing o-rings on "well served" injectors is a waste.
Old May 22, 2022 | 05:16 PM
bwguardian's Avatar
bwguardian
How is ""well served" injectors" with 35k-40k miles "a waste"?
Old May 22, 2022 | 05:23 PM
FinnishStroker
I meant "well served" for several hundreds of K miles..
Yours known-to-be-good..
Excuse my RallyEnglish.
It is veri tankerous.
Old May 22, 2022 | 05:29 PM
bwguardian's Avatar
bwguardian
No worries...that's what I'm trying to figure out. Though they don't have many miles on them, they have been sitting for years...
Old May 22, 2022 | 05:33 PM
FinnishStroker
Sitting too many years may require internal o-rings too..
And next we are down in the RabbitHole..
Old May 22, 2022 | 05:50 PM
bwguardian's Avatar
bwguardian
So there are internal o-rings...I'll research and see what that entails...
Old May 22, 2022 | 06:02 PM
Walleye Hunter
It entails entrails.
Old May 23, 2022 | 12:13 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Calibration fluid is designed for storing injectors. Diesel fuel is not designed for storing injectors.
Old May 23, 2022 | 01:00 PM
ESwift's Avatar
ESwift
CNCFAB
Once installed injectors are fine for 25+years having diesel in them, what is the difference, other then having it replaced with fresh diesel when run?
