Injectors?
Old Jul 24, 2008 | 08:29 PM
pskelton's Avatar
pskelton
Injectors?
Other than getting schwacked at the dealer for a good 70 bucks is there any way to tell which injector is failing?
Old Jul 24, 2008 | 08:35 PM
doubledee715's Avatar
doubledee715
70 bucks to see which injector is failing...that's not too bad. How many have you gone through after 230k?? Or is that kilometers?
Old Jul 24, 2008 | 10:05 PM
tex25025's Avatar
tex25025
I agree, that isn't bad. The only way to tell if an injector is failing if you have a contribution dtc failure for a particular injector, but other then that I don't know of in other way that would be easy.
Old Jul 24, 2008 | 10:20 PM
doubledee715
would an auto enguinity(sp) work?
Old Jul 24, 2008 | 10:30 PM
tex25025's Avatar
tex25025
Oh yea, that should be able to pull codes that are a little bit out of the realm of what tuners could pull.
Old Jul 26, 2008 | 11:34 AM
pskelton's Avatar
pskelton
yes, thats 229k miles. According to the Oasis, the only one thats been replaced is the one i did last fall. I know i should probably just replace them all but thats so much $ at once. I may putt putt into the dealer this afternoon, its lost all power past 2nd.
Old Jul 26, 2008 | 12:35 PM
juneau76's Avatar
juneau76
I know I'm showing my lack of mechanical knowledge asking, but how would a auto enguinity pickup a failed injector? I guess a better question first is what is an auto enguinity?
Old Jul 26, 2008 | 12:55 PM
tex25025's Avatar
tex25025
Diagnostic software for your laptop that is able to read OBD-II parameters. It goes beyond what your able to do with just reading DTCs with tuners. It does datalogging(which xCall II and III does, but it's approach is a little clumsy, but I did do it a few times to tweak my tunes) in order to monitor various parameters in order to find problems(or tweak programming). It can also pull codes that you wouldn't be able to pull with tuners.
Old Jul 26, 2008 | 12:56 PM
doubledee715
may be a tranny issue if it only occurs past 2nd gear....do you notice if the tow haul light is blinking?
I think it is one of the best scan tools out there.
Old Jul 28, 2008 | 05:31 PM
juneau76's Avatar
juneau76
I guess I have a long way to go still on the learning curve for some of this stuff.
