Sponsored by: Real Truck
Rotor hitting caliper mounting bracket.
Old May 24, 2022 | 07:24 PM
Camoclad85's Avatar
Camoclad85
Trailering
Yes, the races bottomed out. I'm thinking now maybe I should tear them apart and double check again.
Old May 25, 2022 | 08:09 AM
WWR's Avatar
WWR
I'm not sure that races not fully seated would cause your symptoms but clearly something is going on. I'd make sure you got the right part numbers....but again, I have no idea if it's possible to get a bearing/race that would fit or press in but is "narrower" or not as tall.
Also are you certain the spindle threads didn't get boogered? You may be torquing up against mangled threads rather than contacting the outer bearing firmly.
Just throwing out ideas, difficult to diagnose without laying hands on it.
This is just one side? Or both sides?
Old May 25, 2022 | 08:12 AM
Camoclad85's Avatar
Camoclad85
Trailering
It's both sides. I don't think the spindle threads are damaged. It does seem like there's play between the hub locking nut and bearing though. It's raining here now, when I get a chance to go back out and pull it off I'll let you know what I find.
Old May 25, 2022 | 08:23 AM
WWR's Avatar
WWR
If it's both sides I'd suspect incorrect parts somehow, or you've duplicated some kind of error on both sides.....I just don't know what that would be.
Send some rain this way, we're already on fire in the Southwest
Old May 25, 2022 | 08:26 AM
projectSHO89's Avatar
projectSHO89
Well, If you take it back apart, snap a photo of the spindle that covers its full length and post it.
Old May 25, 2022 | 07:10 PM
Camoclad85's Avatar
Camoclad85
Trailering
Finally!!!
Just wanted to let y'all know I finally got it right. Apparently I wasn't cranking the nut down completely. I appreciate y'alls help. Thanks!!!
Walleye Hunter
Mar 2, 2018 02:31 PM
Randy Sheats
Dec 23, 2016 02:41 PM
DAPtomey
Nov 28, 2016 01:16 PM
countryboy73703
Jun 5, 2016 08:12 PM
hunt1moore
Jun 9, 2014 05:07 AM
