Foreign TPMS Sensors
Old May 21, 2022 | 07:36 PM
Rob89's Avatar
Rob89
I’m buying a set of Tremor take-off’s in the morning and they have the factory tires and tpms mounted. I don’t yet have a TPMS relearn tool and of course I’m going to want to drive around on the new wheels after I get them. If I put the Tremor take offs on my truck and drive for a few days without doing the relearn and I just going to get a TPMS light or will I also get a check engine light?
Old May 21, 2022 | 07:52 PM
GMB Racing's Avatar
GMB Racing
Just look up how to train them with out the tool. It involves put truck in learn mode and letting air out until horn beeps.
the only light you will get is the TPMS light
Old May 22, 2022 | 09:55 AM
GABAR's Avatar
GABAR
Believe it or not, for some reason, some Fords will automatically detect the OEM TPM sensors after driving around for awhile and no further programming will be required.
If they were truly “foreign” / non-OEM TPM sensors, the above suggestion might not work.
You’re not going to hurt anything by doing this but if it doesn’t work, just get the programming tool off Amazon for less than $20.00 dollars or pull into your local Discount Tire, if you have them in your area, and they’ll program them for you.
Old May 22, 2022 | 11:24 AM
kylant's Avatar
kylant
IF they are OEM sensors, the truck will automatically recognize them.
I just installed a brand new set in my "summer" wheels and mounted the wheels at my house.
I did nothing to the truck to recognize the new sensors. They work just fine. Accurate pressure, no lights. I have driven over 1K miles. The original stock sensors are in the "winter" wheels in the shed.
I fully expected to have to reprogram the truck, but not the case.
Old May 22, 2022 | 11:25 AM
Rob89's Avatar
Rob89
So I put the Tremor take off’s on this morning and my truck automatically detected them.
Wbruiser2
2004 - 2008 F150
Feb 22, 2020 09:29 AM
ATC Crazy
Aug 9, 2019 05:10 AM
mtuser
Feb 2, 2018 11:16 AM
JeepPuller
6.2L V8
Jun 30, 2016 05:43 AM
bememe
2004 - 2008 F150
Dec 26, 2007 08:21 AM
