TPMS Necessary?
Old Feb 1, 2018 | 09:27 AM
mtuser's Avatar
mtuser
TPMS Necessary?
Hey All:
I bought a set of lariat take off wheels for my 2017 and am going to run a dedicated snow tire. The wheels I bought did not include the tpms. Would you spend $200 for four new sensors or would you just run without and deal with the light on the dash? If I do go without can somebody confirm that it is just the light on the dash and that there is no dinging or some other sort of alarm on the truck? I can live with a light but not with some annoying alarm. Thanks in advance.
Old Feb 1, 2018 | 10:09 AM
C_Smitty's Avatar
C_Smitty
It dings once and then the dash will notify you of the tpms issue and then you just hit ok on the steering wheel. The symbol will flash for a few seconds and then will stay on until you shut the truck off. Note that it will only come on if you drive a certain distance and/or the truck has been on for a while. Not sure which it is. My daily communte to work one way is less than 10 miles so I really never see the light come on. Only on weekends when the fam and I take longer trips. In a nut shell it don't bother me.
Old Feb 1, 2018 | 10:12 AM
Buliwyf's Avatar
Buliwyf
I'm considering the same thing. Putting 34" hybrid tires on the OEM 17" rim with the sensors, and picking up a set of OEM 18x9" wheels for 35-36" Maxxis MT's, no sensors.
RainDesert's Avatar
RainDesert
If this does bother someone, is Forscan the only way to turn it off or has anyone found an aftermarket device that will disable?
Old Feb 1, 2018 | 10:19 AM
C_Smitty's Avatar
C_Smitty
Originally Posted by RainDesert
If is does bother someone, is Forscan the only way to turn it off or has anyone found an aftermarket device that will disable?
My truck is tuned with Ez-Lynk and supposedly in there next coming update they are supposed to have the capability to turn off the TPSM light. Thats also why I didnt pay for new sensors in my aftermarket wheels knowing that EZ-Lynk was going to have that capability...
Old Feb 1, 2018 | 11:11 AM
roadpilot's Avatar
roadpilot
Sure. They're called TPMS sensors. Install them in the wheels and it will stop the light/alarming. And they'll also advise you when your tire pressure is low ... whoda thunk it?
Old Feb 1, 2018 | 11:17 AM
Buliwyf's Avatar
Buliwyf
Considered it. I don't want to reprogram every time I swap wheels/tires.
If the truck could find the "new" sensors on it's own, I'd be fine with just buying a 2nd set.
Old Feb 1, 2018 | 11:29 AM
mtuser's Avatar
mtuser
Do you know what the reprogramming entails? Is it a pretty easy process? I assume my tire shop would take care of that but will have to check with them.
Old Feb 1, 2018 | 12:08 PM
RainDesert's Avatar
RainDesert
Thank you for the insightful contribution to this thread.
Old Feb 1, 2018 | 12:50 PM
HRTKD's Avatar
HRTKD
Discount Tire has a set of sensors they call EZ Program. The new sensors can be set to mimic your current sensors. So when you swap from summer to winter tires/wheels/sensors the truck doesn't know the difference.
Old Feb 1, 2018 | 01:35 PM
1956Fatfenders's Avatar
1956Fatfenders
Likely these:
Schrader EZ-sensor
Old Feb 2, 2018 | 09:30 AM
First Dually's Avatar
First Dually
And to think I'm all disappointed that TPMS is not available with the F450. To each there own! LOL
Old Feb 2, 2018 | 11:15 AM
roadpilot's Avatar
roadpilot
Just wait. Next thread will be: How do I disable that annoying buzzer when I don't wear my seat belt.
Old Feb 2, 2018 | 11:16 AM
roadpilot's Avatar
roadpilot
You don't do a very good job of recognizing humor, do you?
Larietpsd
Jan 29, 2016 09:11 PM
Denola
Jul 5, 2015 11:45 PM
farwhitenorth
Feb 17, 2014 10:03 AM
2012 SD Snowbuster
2004 - 2008 F150
Oct 27, 2011 06:49 AM
bememe
2004 - 2008 F150
Dec 26, 2007 08:21 AM
