noise??
Old Nov 8, 2003 | 09:07 PM
1979fordf150's Avatar
1979fordf150
noise??
I just got a 79 f150 with a 351 for 800 bucks and there is this noise that sounds like it is comming from the front end but I am not sure it sounds alot like tire droan ( the sound you get with real big tires) but the tires that are on it are just normal tires. the sound is noticable at speeds above 25mph if anybody has any ideas what it is and a possible solution it would be great.
Old Nov 9, 2003 | 02:50 PM
mrsuperman15's Avatar
mrsuperman15
does it only make the sound when you are giving it gas? mine had a similar noise shortly after i got it turned out it was the third member, it was shot and had to be replaced, it really only made the noise when giving it gas, if this is the case the longer you drive it like this the more it will tear up, it cost me about 600.00 to fix mine i hope this is not your problem
Old Nov 9, 2003 | 03:46 PM
1979fordf150
no it does it all the time when brakeing or coasting i can even put it in neutral and it does it the noise doesnt really start until about 25 but it continues all the way to zero
Old Nov 9, 2003 | 06:36 PM
buzzbait65's Avatar
buzzbait65
check your wheel bearings......
Old Nov 9, 2003 | 11:12 PM
chevey hater77's Avatar
chevey hater77
your tires may be out of ballence.
fordguy4life
1997 - 2003 F150
May 8, 2011 09:55 AM
ycymry
1997 - 2003 F150
Mar 13, 2010 08:58 AM
catan70
1997 - 2003 F150
Jan 23, 2010 09:35 PM
Rock krawler
1997 - 2003 F150
Nov 14, 2006 04:31 PM
roy1986f250
Nov 23, 2000 12:19 AM
